Hi
I would check out the radio features and make sure the radio isn't on mute or the fader is turned in the wrong direction or there is another button depressed muting the sound.
if that s ok you will have to remove the radio and check to see if the speaker wires are still connected to the stereo
if they are you will have to remove the door trims and see if the wires are still connected to the speakers as well
check the radio features first
cheers
SOURCE: Hi My nissan Pathfinder 2006 model s vibrates when is on
Has your fuel economy dropped? It may not have, what it sounds like to me is a low rpm miss. You could have a dirty injector or injectors, hard to tell unless hooked up to engine analyzer
SOURCE: check engine light on 40,000 miles nissan pathfinder 2006
You must scan the Engine Control Module and collect fault codes before it can be determined why your engine controller turned the light on.
SOURCE: Where is pollen filter,nissan pathfinder 2006?
open the glove box and press on one side to get it open completely
remove the screw on the cover
remove the air filter
make sure you put the new one in with the right dirrection of air flow
