I do can start up the laptop only if the battery(completely discharged) installed and Power connected. If I remove the battery and connect the AC adapter I can not start up. Power light is glows but when I try to start up the laptop light goes down and then glows again but nothing happens.I do can start up the laptop only if the battery(completely discharged) installed and Power connected. If I remove the battery and connect the AC adapter I can not start up. Power light is glows but when I try to start up the laptop light goes down and then glows again but nothing happens.
It doesn't help. I can start only from the battery. When I try start from the Power Adapter power led is glow but nothing happens after pressing the start button. If the Power Adapter connected to wall and the battery inserted the battery charge led is not glow and the battery is not charging.It doesn't help. I can start only from the battery. When I try start from the Power Adapter power led is glow but nothing happens after pressing the start button. If the Power Adapter connected to wall and the battery inserted the battery charge led is not glow and the battery is not charging.
You can't post conmments that contain an email address.
Get to the mainboard there is a jumper near the cmos battery usually shows the word (jbat) near it , try to change its position for some seconds while power is off , this way will clear cmos and set the mainboard bios to default settings. start the system hit delete or F2 to enter setup then exit saving changes.
smtime low cmos battery could cause the pc not to start
A steady or Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Hard restart your machine by pressing and holding the power button until all the indicator led's are off, remove the battery and press and hold the power button again. Reinsert the battery, press the power button and immediately start pressing F2 repeatedly until the bios menu comes up.
OK so you have to perform hard reset.
You do this by pressing and holding the power and calender button, then pressing and releasing
the reset button. You continue to hold the power and calender buttons
for a few seconds. When you release the power and calender buttons the
unit should beep and then reset.
check power supply if you have power on it check power button if is not working try unplug it and connentit after 5 min if it is not sturting you need to replace power transformer
HP SUPPORT COMMUNICATION -
CUSTOMER NOTICE
Document ID: c01764371 Version: 1
Notice: HP Flat Panel Monitors - Pressing Menu Button Or Power Button Has No Effect Other Than To Display A Warning Message
NOTICE: The information in this document, including products and
software versions, is current as of the Release Date. This document is
subject to change without notice.
Release Date: 2009-06-05 Last Updated: 2009-06-05
DESCRIPTION
Many newer HP monitors have a feature that allows users to disable the front panel
Menu
and
Power
buttons. When they are disabled, pressing them has no effect other than
to display on-screen warning messages.
DETAILS
If the
Power
button is disabled; pressing it displays this message:
Power Button Lockout
If the
Menu
button disabled, pressing it displays this message:
OSD Lockout
The buttons can be re-enabled as follows:
If the
Power
button is disabled, press and hold it for 10 seconds to unlock it.
If the
Menu
NOTE
If the
Power
or
Menu
buttons are not disabled, pressing and holding them for 10 seconds will
disabled them. Here's the site..... http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=3548687&prodTypeId=382087&objectID=c01764371
