SOURCE: 25cc weed eater, will only idle
double check your carb as it should have a screw for the fuel mixture. some carbs have a plastic piece over them that only lets you move the screws so far if you need more extreme adjustment they pull out about a 1/8th of a inch then you can turn in then push it back in, same principals as making a flame on a bic lighter bigger, if you cant find it take some pics of your carb and email them to me @ [email protected] and i will point them out
SOURCE: poulan ppb 250 weed eater, only runs with choke on,
HOW IS YOUR FUEL LINES. SOUNDS LIKE IT MAY HAVE A AIR LEAK
SOURCE: I have a snapper S31SST weed eater. It is 4-5
Remove spark plug and check for fire with a spark tester. (some inline models are also available and safer since the spark plug stays in place using those types)
If no spark:
Remove covers and unplug small kill-circuit wire(s) from ignition coil...Test for spark.
If you have spark the switch needs replacing.
If you have no spark the coil needs replacing.
Hope this helps.
SOURCE: My weed eater will not idle. When I removed my
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
Be careful when blowing out the passages because there are sometimes small rubber type seats in the bottom of some of the passages.
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
Keep in mind that the float for the carburetor must be level when you go to reassemble the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
SOURCE: I have a RYOBI weed eater model ss30. I can get
Check your fuel filter in the fuel tank,if you have one it may need cleaning or replacement.
If the mower/weedeater is over a year old, then I recommend that you buy
Sounds like you will need to clean the carburetor or replace your carburetor
internal rubber parts like the diaphgram and O rings.
Be careful when blowing out the passages, because there are sometimes small
Sometimes you can get by with priming the carburetor or using starting fluid
reassemble the carburetor or follow the instructions you get with the
carburetor kit.
When you clean your carburetor and remove the jet screws, you will first need
to lightly seat the jet screws.
But before you lightly seat the jet screws count the number of turns it takes
to seat the jet screws from their original position.
Be sure to mark the turns down on a piece of paper.
That way when you put the jets back in, you know to lightly seat them first
and then turn them back out to their orginal position before you started.
This is a FREE answer,Please rate me
