Question about Acer Aspire 3680 Laptop
Phantom 'd' key
The 'd' character keeps coming up on screen without me pressing the key. It stops me from clicking on anything else and even when I delete the characters they keep poping up on screen as though I have the key depressed. I had the keyboard checked out and there isn't a short circuit or anything. It also stops me from rebooting properly.
  • 324 Answers
There are only two reasons, that I know of, that would cause this problem. Either the keyboard or the keyboard interface chip on the motherboard. Of the two, I would suspect the keyboard more. Even though you have had the keyboard checked out, I'd suggest doing a double check. It could be the "D" key mechanism itself, the associated keyboard circuitry, the keyboard cable or the cable connector.
I don't remember, right off hand, does this model have a way of connecting an external keyboard? If so, try that. If it works, you've just verified 95% of the motherboard as being OK.
The ideal way of checking out a problem would be to swap out the keyboard from a similar unit, but would imagine you would have already tried that if you had access to one. If you are absolutely sure that the keyboard is OK, then the only choice that you have is to replace the motherboard. OH! One other thing to check might be the connector on the motherboard. Look at it very closely to insure that there is no foreign material in it and that all of the contacts are uniformly formed and lined up.
If I think of anything else, I'll let you know.
If you can add anything else that might help, or have any questions, please ask!
Posted on Nov 15, 2007
  • Ron Roske Nov 20, 2007
    Good evening!
    Just thought that I'd check back with you to see if you've made any progress on this issue, or if you have any other questions.
How do i change the business name, address and abn on the receipts for a Samsung ER-650
Turn key to "PGM"
Press "7"
From the
LOGO DESC. PROGRAM screen, press "0" to display the PREAMBLE screen:
Using the alpha numeric keyboard overlay, type the first line of the message.
Each line (6 allowed) can be up to 32 characters, although only the last 19 characters you have entered will display. If you make a mistake, press the "BACKSPACE" key to erase the previous character. After you have completed typing the first line, press "ENTER"
to accept the new line and advance to the second line, or press
to return to the LOGO DESC. PROGRAM screen without making any changes.
Thank You
Jan 29, 2015 | Samsung SAM4s ER-650 Cash Register
How to fix sticky keys
You must increase the leadtime before Windows considers your keeping a key pressed down means you want to repeat it.
Open Keyboard Properties by clicking the Start button , and then clicking Control Panel. In the search box, type keyboard, and then click Keyboard.
Under Character repeat, move the Repeat delay slider to the right to increase how long you must hold down a key before the keyboard character repeats, and then click OK.
Jul 24, 2014 | HP Pavilion Computers & Internet
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 09, 2013 | Horizon T203 Treadmill
When not on line i keep getting play store coming up retry to go online how do i stop this
Hello john, to stop it, press the windows key on your keyboard and the R key to bring the run box. then type "msconfig" without the quote in the box. a box will show, click the startup tab. the look for play store from the list and uncheck it. apply and restart your pc
Oct 17, 2012 | Archos 101 Internet Tablet
How do I restore my pc back to factory settingg
1) Turn on your computer. Right away there will be a black screen. You can restore factory settings without a CD, too. This will reset your BIOS.
  • 2) Press F1 when the black screen appears; you will enter the setup configuration mode. You will be presented with a menu.
  • 3) Select Restore Factory Defaults. Your computer will do all the work for you. As with the CD, this process may take several hours.
  • OR
    As soon as your computer is turning on press the F10 key and it will take you to the system recovery screen, click on the advanced option and click Destructive recovery and click next. WARNING: before doing this backup anything on your computer you want to keep pictures,videos,music etc.. this will delete everything that did not come pre-loaded from the factory, so if you have pictures of Aunt Fae's Class reunion you should probably back those up if you wanna keep them.
    To keep your PC fresh and optimize it to best performance use system utility software RegInOut
    Dec 15, 2011 | HP Computers & Internet
    I had the same problem. When I pressed shift and that comma key I got a " instead of a @.
    I looked to see what on the leyboard you normally press to get a " and that's the number 2 key.
    Tried pressing shift and the 2 key and hey presto, I got a @.
    So it looks like @ and " have swapped places.
    So shift and 2 for a @!
    Lizzie H
    Oct 24, 2008 | Computers & Internet
    Phantom Key
    Try hitting the S key and check for clips, staples, lint, food, fingernails or other debris that may be holding it down, if you can, pry off the key and check it as well, carefully blow on it.
    Aug 23, 2008 | Acer TravelMate 2300 Notebook
    Phantom 'd' key
    ok try this gently pry off the d key and look and see if there is any junk aor anything that will make it not work properly and make sure to clean the whole area arond it and in it and then put the key back and go and press the key about a dozenb times and see if it resoponds correctly ok please keep me posted on this ok best regards mike
    You have set a resolution that is too high or incompatible with your monitor. I assume you are using Windows. Turn the computer on and immediately keep pressing F8 on the keyboard until the 'Windows Advanced Options Menu' appears. Use the Up and Down keys to select 'Enable VGA Mode' Press enter and your screen will work again when windows starts. Now go to the display properties and click 'Advanced' then click the 'Monitor' tab and tick 'Hide modes that this monitor cannot display' OK everthing and now you should be able to adjust the resolution without getting a blank screen again! Good luck and come back to comment soon. Regards
    Sep 26, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
    Keyboard data entry
    Sounds like a classic problem for a driver/firmware update. get an update here before trying anything else- If it still doesn't solve it you might need to format it and reinstall everything from scratch. Good luck
    Apr 22, 2006 | Palm Tungsten C Handheld
    Acer Aspire 3680 Laptop Logo
    57 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
