Zanussi F1045W Front Load Washer
Problem for Zanussi F1045W Front Load Washer
Machine will not drain
By jmp1942 on Jul 11, 2009
The washing machine does not drain.
Best Solution
posted on Jul 11, 2009
Helpful)
PCmania
Rank: Wiz
Rating: 83%, 264 votes
Hi..
If your machine does not drain you need to check this
  • Inspect the drain hose for kinks
  • Test the timer control
  • Test the lid switch (some models)
  • Inspect the water pump
  • Inspect the drive belt (belt drive only)
  • Inspect the motor coupler
Before testing the lid switch, unplug the washer or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
Regards
PCmania
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Nov 07, 2009
Not Rated)
bridera
Rank: Apprentice
Rating: 0%, 0 votes
Could you have it at the wrong setting. Mine drains automatically at setting C and setting D. If I use setting J I have to remember to manually set it to J to drain
Comments:
Nov 07, 2009
- Sorry, I meant that I have to manually set it to G to drain!
Was this helpful?
Yes
No
Popular Solutions for Zanussi F1045W Front Load
Questions and Unsolved Problems for Zanussi F1045W Front Load
Do you recommend Zanussi F1045W Front Load Washer?
Answer
Answer
Was banging and now the Drum belt keeps coming off.
Answer
i select either spin cycle it rotates to balance load then it trys to speed up then stops
Answer
How do i replace the timer on a zanussi aquacycle 1000 model no.f1045w.Product no.914792004
Answer
Zanussi FS1455W - The machine does not wash, even though it sounds as though it will begin washing,... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zanussi F1045W Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
