Question about Canon PIXMA MP780 All-In-One InkJet Printer
Connection Ever since switching to high speed internet instead of dial up, my printer doesn't receive info. from the computer to print. It copies just fine and looks like it's working fine. I don't know how to hook it up so the computer can communicate with it.
  • 2,427 Answers
Unplug your printer and unistall the drivers
reinstall your drivers and plug back in your printer
Posted on Dec 31, 2007
How do I set up on my printer to connect fax
Pl. connect the CO(telephone line) to the socket marked as LINE.
from the key board there is FAX switch select it.
To send a fax load the document face upward, if ADF is used or face downward at platen glass, press SPK or OHD or phone as marked on the key board get the audible dial tone, dial the required fax no. get the fax tone press START. If the display shows sending then alright. If display show !-SENDING,2-RECEIVING, then press the corresponding digit.
Feb 18, 2015 | Samsung Xpress SL-C460FW Laser...
Where is the wireless switch on the dell vostro 200
Unlike notebook computers, most desktops don't come with wireless networking built in. I can't find any mention on Dell's site that the Vostro 200 has wireless capability, so this computer doesn't have a wireless switch. To use your desktop computer on a wireless network, you'll need to install a wireless adapter. USB adapters are very easy to use since you just have to plug them in. They're not expensive and you can easily find them at retail stores and online.
Jun 13, 2011 | Dell Vostro 200 PC Desktop
Woth use ethernet cotroller for
The ethernet controller card in the computer is used to connect to a home or office network and or to the Internet.
Feb 22, 2011 | Computers & Internet
I have dial up. Updates of more than a few Megabites time out. How can i overcome this? Every time when the update is large. Once I was cut off after downloading about 50 Mb. loosing all info thus far...
Unfortunately these days dial up is not sustainable for anything other than Faxing. With file sizes continue to increase you want to consider high speed internet. Another option would be using a smart phone with a data plan to thether high speed using wifi.
Oct 25, 2017 | Symantec Norton 360 Version 2.0 for PC
Is there a Fax modem available to be connected with scanner, copier and printer (three in one already with us.)
your unit has a fax installed in the unit.
Look at page 29 in your manual it will show how to send and receive a fax.
send a fax page 29
receive a fax page 32
print reports page 33
feature purpose
1 Phone Hook: the green LED in the shape of a phone indicates that the fax
line is in use when lit.
2 One-Touch Speed-Dial Buttons: use to access the first 6 speed-dial entries.
3 Auto Answer: when the green light is on, fax transmissions will
automatically be accepted.
4 Speed Dial: use to access speed-dial numbers that have been set up from
the front panel or with the HP Director software.
5 Redial/Pause: redials the most recently dialed number when in the ready
state. Inserts a pause (hyphen) when in the dialing state.
6 Keypad: use to dial fax numbers, and enter numbers such as the quantity
of copies or percentages when reducing or enlarging. You can also enter
text using the keypad for fax header, use speed dial entries, and specify
menu items.
7 Fax Resolution: use to set the fax resolution to Fine, Standard, 300 dpi,
or Photo. It will remain at the most recent setting until changed.
8 Start Fax - Black: starts a black and white fax.
9 Start Fax - Color: starts a color fax
Apr 27, 2010 | HP OfficeJet 6110 All-In-One InkJet...
It is not possible to email the scanned file directly through the printer. However, you may send fax over the Internet
You may subscribe to a low cost phone service that allows you to send and receive faxes with your device by using the Internet. This method is called Fax over Internet Protocol (FoIP). You probably use a FoIP service (provided by your telephone company) if you:
• Dial a special access code along with the fax number, or
• Have an IP converter box that connects to the Internet and provides analog phone ports for the fax connection.
NOTE: You can only send and receive faxes by connecting a phone cord to the port labeled "1-LINE" on the device. This means that your connection to the Internet must be done either through a converter box (which supplies regular analog phone jacks for fax connections) or your telephone company.
Some Internet faxing services do not work properly when the device is sending and receiving faxes at high speed (33600bps). If you experience problems sending and receiving faxes while using an Internet fax service, use a slower fax speed. You can do this by changing the Fax Speed setting from High (the default) to Medium. For information on changing this setting, see Set the fax speed. If you have questions about internet faxing, contact your internet faxing services
support department.
(Ref from the manual of the printer.)
Hope this helps.
Jan 23, 2010 | HP OfficeJet J4580 All-In-One Laser...
You can attach the printer directly through USB cable to your computer and print, or you can connect the printer and your computer to the same wireless network and then print using the wireless and your connection.
Internet is not necessary, only a communication path needs to be established. For this whether its your neighbor's wifi network, your own wifi network, a usb cable connection between your pc and printer etc printing will be accomplished.
Dec 30, 2009 | Brother MFC 240C All-In-One InkJet Printer
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Pls help how to fix my anti virus tat still connected to the inte
Try running the exe file from the location itself (Click on Run, instead of Save and then try. :)
Is it a dial up or high speed connection.
Goto internet properties under control panel, goto connections tab - Is there any connection listed/created in the "Dial Up/VPN "box on the top
Dec 08, 2008 | Acer Aspire 5500 5570-2609 Laptop
I cannot print pages from my computer. The message says no communication. I can fax, receive faxes, copy and scan. I just can't print from the computer, everything is connected.
try checking ur usb cable... if that is ok then check ur printer prefrence to make sure one it is ur default printer and two it is set to send print info to that printer
Nov 04, 2008 | Computers & Internet
Canon PIXMA MP780 All-In-One InkJet Printer Logo
23 people viewed this question
old marine
old marine
