I close the gate in the morning but find it open when I return home from work in the evening. This does not happen at night and it does not happen every day.Last week it happened on 3 consecutive days
There are several ways a gate will open. You need to check each of them but the most common issue we find when repairing gates is the exiting vehicle detection device is opening the gate.
There are two main types. The best type will be a loop embedded in the driveway. These normally open the gate by driving over them. A sensor in the operator sends an electrical wave through the loop. A vehicle affects this wave and the sensor detects it, flips a switch and opens the gate.
If the installer used standard PVC wire, and the driveway cracks to let water sit on the wires, they could change the wave occasionally and open the gate. Water can take days to soak through and remain around for days. So while you do not have rain or sprinklers going the day the gate opens, it could still be the cause.
The sensor inside the operator could also be going out. Usually, they have lights showing when they are active. If you have one, and the detection light is on, turn off the machine, disconnect and reconnect the sensor and see if the detection light comes back on.
Next check the loop wires. Physically, look at the wires wherever you can. Check the driveway for exposed wires. If you find them, call a pro to replace them. Once this is done, you need an ohmmeter. Plunge a screwdriver deep in the ground. Set the dial on the ohmmeter to measure how much resistance there is between one wire in the loop and the screwdriver in the ground. Make sure you are not touching the leads or wires with both hands since you will be measuring your bodies resistance and not the short between the ground and the wires you are looking for.
If you find anything but an open circuit, there is a problem with the loop wires and you will need to replace them. If you have a completely open circuit, then change the detector. Ideally, you have another detector for the safety loops and can switch them to see if the problem moves to the safety loops. If it does, replace the detector.
The second type of exit device is called an exit wand or exit probe.
These are overly sensitive and don't last as long as the loop detector. Your dogs collar can set it off as can a bicycle or even a workers steel-toed boots. Add to this, the propensity to fail, and if you have one of these, you have likely found the problem.
The fix for these is to pull the probe up, look for nicks or cuts in the wire and fix them, dig a deeper trench, cover the wire with PVC pipe to prevent more cuts and finally bury the wand itself at least six inches deep. By the way, if the probe cable runs next to other electrical lines, they can make the probe react too. I have heard this can be prevented by using copper pipe instead of PVC pipe.
Other causes could be a remote in someones purse or pocket going off as it bumps around, a switch used to open the gate shorting out, a call box getting signals and in general anything used to open the gate breaking down or being set off inadvertently.
Rarely, and I mean very rarely, a control board, the big circuit board controlling the gate motor itself, will go out and cause this sort of problem. Out of everything, this is the least likely.
Good luck.
NOTE:If the power liftgate system is turned OFF in the message center, the system cannot be activated with any switches or with the liftgate handle. The system will need to be turned ON for any power operation to occur.
NOTE:The power liftgate may not operate under the following conditions:
Power Liftgate Module Diagnostic Trouble Code (DTC) Index
DTC
Description
Source
Action
B1342
ECU Is Defective
INSTALL a new power liftgate module. REFER to Power Liftgate Modulein this section.
B2477
Module Configuration Failure
REFER to Section 418-01.
B2522
Vbatt1 Circuit Failure
GO to Pinpoint Test B.
B2552
Vbatt2 Circuit Open
B2698
Vbatt2 Circuit Failure
B2699
Left Pinch Strip Open Or Short To Battery
B2700
Right Pinch Strip Open Or Short To Battery
B2701
Left Pinch Strip Stuck Active
B2702
Right Pinch Strip Stuck Active
B2703
Open/Close Switch Stuck Active
B2704
Optical Sensor Power Short To Ground
B2705
Optical Sensor 1 Input Not Active During Powered Gate Movement
B2706
Optical Sensor 2 Input Not Active During Powered Gate Movement
B2709
Gate Open Output Short To Battery
B2710
Gate Close Output Short To Battery
B2711
Gate Open Output Short To Ground Or Open
B2712
Gate Close Output Short To Ground Or Open
B2713
Unlatch Output Short To Ground Or Open
B2714
Uncinch Output Short To Ground Or Open
B2715
Cinch Output Short To Ground Or Open
B2718
Gate Ajar Output Short To Battery
B2721
Gate Ajar Output Short To Ground Or Open
B2722
Open/Close Switch Active During Self-Test
B2723
Glass Position Switch Active During Self-Test
B2724
Forkbolt Switch Invalid During Self-Test
B2725
Detent Switch Invalid During Self-Test
B2726
Home Switch Invalid During Self-Test
B2819
Gate Motor Circuit Short To Battery
B2820
Gate Motor Circuit Short To Ground Or Open
B2821
Cincher Motor/Unlatch Actuator Short To Ground Or Open
B2822
Cincher Motor/Unlatch Actuator Short To Battery
B2825
Movement Ceased Due To Excess Speed Deviation
B2903
Chime Output Circuit Short To Battery
Power Liftgate Module/ Liftgate Chime Module
GO to Pinpoint Test C.
C1935
Chime Circuit Failure
U1950
UBP Communication BUS Fault
UBP Communi cation
REFER to Section 418-00.
U2338
Invalid ACM Message Data
