Sony BRAVIA KDL-46S2010 46" LCD TV Logo
K
KENNETH LOTT Posted on May 30, 2015
ON THE VERY TOP OF SCREEN, I HAVE LINE WITH "NO SIGNAL" ON LEFT SIDE AND A NUMBER 3 ON THE RIGHT SIDE. ANY SUGGESTIONS
WAS TRYING TO CHANGE THE SIZE OF THE PICTURE ON SCREEN.
George Centrella
Level 1:
New Friend:
  • Contributor 25 Answers
  • Posted on Jun 07, 2015
George Centrella
Contributor
Level 1:
New Friend:
Answers
25
Questions
Helped
12417
Points
55
You might just need to press the source button on TV remote so a box pops up on the screen giving you options like tv,hdmi1,hdmi2 or av1,av2. Hopefully its a little helpful.
1 Related Answer
gopakumarg43
  • 76851 Answers
  • Posted on May 30, 2015
SOURCE: NO PICTURE ON SCREEN. HAVE A LINE AT TOP OF SCREEN WITH A NO SIGNAL ON LEFT SIDE AND NUMBER 3 ON THE FAR RIGHT SIDE.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
1helpful
Craftsman 33cc weedwacker rep lace fuel lines
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
2helpful
Fuel line diagram for sears mini cultivator
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
3helpful
Internal line in gas tank came loose
Craftman trimmers has two gas lines wich one goes to the primmer the one with the filter or the thine one
Jan 09, 2012 • Garden
A yellow line going down the left side of the television
you likely have the "screen size" option set to allow the TV determine the best size (3:4 , 16:9, ...). Set it manually to 16:9 for HD channels or 3:4 for low-def channels.
The line should go away. This is a common problem on Samsung, Sony (Green line right side) and Phillips (yellow line left side).
Vizio P42hd approx. 1" red line on screen, picture shifted
You will need to replace the control board and your TV will be better that a new one.
Sony Bravia 42" Horizontal Lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Code for sony dvd combo slv-d350p
I found this on a forum on line but it doesn't look promising. One person said this worked and one other said it didn't - only two entries though.
1)No disc & tray closed
2)Once the "Insert disk" message in the top-left side of the screen appears, press (in the remote) the Subtitle key and continue with 29334 in sequence.
3)A number(1 in my case)appears in the top-left side of the screen. I believe that this number represents the region code of your DVD equip.
4)Change the number by typing number 0.
5)To save press the "open/close" key and then Enter (small one at the top. Not the big one at the bottom!!)
6)Now check if it works.
NOTE: Other way to check if the change was successful, is to repeat steps 1 to 2. You should then see a 0 in top-left side of the screen.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
