Do I need to open ports?
Trying to connect my play station 2 to the internet
had no problems with DSL and since moved and have cable internet
cannot make a connection with the internet
my isp (Earthlink/Time Warner) does not block p2p but there doesn't seem to be any way to open ports on a RCA DCM425?
    Problem Solver:
  • 12 Answers
Re: do I need to open ports?
There are no ports to open on the DCM425, as it's a cable modem, not a firewall. Earthlink/Time Warner will likely not be truthful when it comes to blocking ports on their end. Would it be possible to change the port that your PS2 is using?
Same goes for the bittorrent question, only I'd switch to uTorrent and different ports as well.
Posted on Feb 24, 2008
0 characters
3 Points
How can I connect the router to my laptop if I don't have any internet. I mean I do have internet connection available on my landline but I need to set it all up on the laptop. how can I do this? I...
Use a 2-wire or 4-wire cable to connect from the telephone-jack to the telephone-port on your DSL modem/router combination device.
Use an 8-wire Ethernet cable to connect from one of the 'LAN' ports on the router to the network-port on your laptop.
Then, you will have Internet access, and, if this router also has a "wireless" capability, you can configure it to provide wireless access to your computer(s).
Mar 30, 2011 | D-Link ADSL 2+ Ethernet/USB Annex A Modem...
I have a dell Inspiron 5000 and want to connect it to the internet using DSL cable. There is no DSL slot to plug into. How do I fix this? Thanks.
Your Internet Service Provider will have provided a DSL-adapter to you.
Connect one 4-wire cable from the adapter to the telephone wall-jack.
Connect one (8-wire) Ethernet cable from the adapter to the network port on your Dell.
Dec 20, 2010 | Dell Modem Board for Inspiron 5000 R600...
How to get it online with a ps3? I hooked it up to the ps3 with the Ethernet cable. It says connection failed .but it wont go online. Any help would be dearly needed. Thanks
First test the Internet connection by connecting a LAN cable from your DSL or cable modem to your computer and see if you can get into the Internet.
If you can't access the Internet then phone your ISP and get them to test your connection to your modem.
If the Internet connection is OK then click on this WEB site and follow the instruction to configure the PS3 :-
Jan 01, 2010 | Arris SURFboard SB5101 Cable Modem
1st time installation: cannot install modem properly
Hey try this one, if doesn't work let me know. First you have to powercyle your modem - meaning turn it off for 10 to 25 seconds then power it up again. Then check status of the modem lights. It should all be in solid green. Else you have to check if cables are properly connected - Data cable (green cable) one end connected to the filter with labeled "DSL/PHN" or the one with monitor engraved, then other end connected to the green port on the back of your modem. Then check also connection of filter to walljack. After which check status of the lights. If still not all in solid green. Check devices near to your modem, these might be the reason for interference of DSL signal. Electronic such as monitors, speakers... must be 2-3 feet away from your modem. Check modem lights. If all in green, test connection. Also there should only be one phone jack connected to your DSL phone line.
Jan 14, 2009 | AT&T High Speed DSL Modem
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
DSL modem connected but no internet
Have you installed DSL filters on all your phones and make sure you don't have on on the line for your modem?
Jun 28, 2008 | Westell Wirespeed LiteLine 6100...
Configuring DSL for All RJ-45 Jacks
the simpliest way is to have a wireless/ wired 4 ports router and install it beside your modem and locate where your Cat 5 cables central end is. Identify the Cat 5s that are connected to the 5 locations of your PCs if all of them are not capable of wireless connection you need to add a switch (4 port or 8 port) which you also need to connect to one Lan port of your router.
Hope this helps.
Apr 11, 2008 | Modems
Try the following forum - it works!
Jan 28, 2008 | D-Link DSL 302G (DSL-302G) Modem
Router setup help
You need to connect the cable that you used to connect to your PC, to the WAN port on the router (it might say internet). Then, you need to connect one of the computers to one of the LAN ports (might have numbers, so you connect it to 1). You then need to login to the router through your browser (generally the address is but you should check the documentation) and ask your ISP for the PPPoE information so you can setup your router to dialup for you (otherwise you could use the dialer you've had on your PC, but that doesn't work as well because you might have to share the internet connection).
Jan 06, 2008 | Modems
694 people viewed this question
Top RCA Modems Experts
Mike McWhinney
Starnley Johnwells
Starnley Johnwells
Are you a RCA Modem Expert? Answer questions, earn points and help others
