Question about Microsoft Xbox 360 Console
Connecting me and my house mate wanna connect our xbox'x 2gether from upstairs 2 down.ive got an ethernet cable but cant seem 2 do it.can you help ??
    Scholar:
  • 31 Answers
Hi.
This is an easy to fix problem but your ethernet cable is not going to work.
What you need is a special cable that is called a cross-over cable - you can purchase this from most computer stores, however if the length needed is longer than 12 feet you may have trouble finding the cable. You can either use an adapter or have a cable custom made for you - and computer repair shop that offers setup services should be able to mae the cable for you - I do this all the time for my local clients.
Once you have the cross-over cable, plug that into both systems, load the game that you want to play and then engage system link - you do not need to do anything with the IP settings on either system as peer-to-peer play like this uses system link and not the IP network.
Have fun!
Posted on Nov 15, 2007
I can connect to xbox live wireless when in same room as router but go upstairs and can not connect..help please
Could be due to metal in the floor like insulation shielding the radio.
Would suggest using a power point switch if power points are on same power circuit
http://www.techbuy.com.au/searchcat/NETWORKING_ETHERNET_OVER_POWER.asp
and then either connect power point network switch to another wireless access point upstairs to cover upstairs area. All settings have to be the same as wi fi router down stairs. Same encryption password . Or you could just plug the Xbox into the power point ethernet network switch via ethernet blue cable.
Jan 27, 2015 | Video Game Consoles & Games
I need to use my laptop to connect my xbox online
Get yourself a pair of homeplugs.
http://lmgtfy.com/?q=homeplugs
Connect 1 homeplug next to your modem and connect it to the modem. Then connect the other one to your xbox and you should get your network working to it.
Nov 09, 2011 | Microsoft Xbox 360 Console
Cant connect my xbox to the internet to play on line
First you need a house internet connection. Check if your xbox is connected via a Ethernet cable or wireless router. After you finish go to console settings and do a connection test.
Jun 27, 2011 | Microsoft Xbox 360 Arcade (4 GB) Console
I have a siemens gigaset se587 wireless router and a xbox360 network adapter it does not connect up to my network where am i going wrong I have connected it up using the ethernet cable and it works fine...
sorry to bother but i cant get xbox live to work with the ethernet cable, where did u plug the ethernet cable into? ive tried different places and none seem to be working
Oct 17, 2009 | Microsoft Wireless Network Adapter Xbox...
Trying to connect a wired network wirelessly to a router
No. You'll need to run a "cross-over" Ethernet cable from one of the "LAN" ports on the "downstairs" router, connecting to the "WAN" port on another router that you will need to buy, and place "upstairs", and connect the 4 devices to the 4 "LAN" ports.
Or, run a long "straight-through" Ethernet cable from your DSL-modem (or cable-modem) that is "downstairs", and move your wireless router "upstairs", and connect the 4 devices to the router's "LAN" ports.
Your laptop "downstairs" should still be able to connect (wirelessly) to the wireless-router that is "upstairs".
Sep 16, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Setting up xbox live
Have you tried testing the connection with your xbox (system settings/network settings). where does it fail? Also make sure your router is set up to hand out IP addresses
Mar 29, 2009 | Microsoft Xbox 360 White Console
Home Network Problem with Netgear MR814 and Netgear FS105
Is your ReplayTV and Xbox configured to use DHCP? If not, you may need to configure static IP addresses for each of them.
Feb 17, 2009 | NetGear ProSafe FS105 5-Port Ethernet...
Cant connect to xbox live via my voyager 210 router from Bt
2 things you can try:-
1. make sure you enter the subnet mask and the gateway on the xbox
You can get these values on a connected computer
2. Try connecting to the Netgear and changing the channel if in UK try channel 4 or 7
Jan 05, 2009 | Computers & Internet
Connecting powerline ethernet adapters through orange livebox
Try to eliminate the problem into smaller parts. Try networking the two via the same power outlet via a multiple power board first in the same room. I don't have much experience with these powerline ethernet but i'm sure the configuration of these will be very similar as wireless router / access points and wireless adapter cards. However what I do know is that your power outlets need to be on the same "phase" of your electrical power system, so if you do this test I suggest (from one outlet board) you know the equipment works and your setup procedure works. then try seperating again and if it still doesnt work, check if your power outlets are wired on seperate phases (depends if your house has 3 phase wiring incoming to your home or not). Try another room or another outlet.
Oct 13, 2007 | Powerline Ethernet Network Adapter
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
