Technique 8.5 qt. Round Digital Stainless Steel Pressure Cooker - Stainless - Logo
s
sylvia clontz Posted on May 29, 2015
Where to purchase electrical cord to plug in to cookefr
Hi . I'm moving from USA to Europe. Can I use my HP 2159m monitor with 220 V instead of 110 ?
Yes. But you'll need a different power cord:
The monitor power supply is provided with Automatic Line Switching (ALS).
This feature allows the monitor to operate on input voltages between 100-240Vv, 50/60 Hz, 1.5A.
The power cord set (flexible cord or wall plug) received with the monitor meets the requirements for use in the country/region where you purchased the equipment.
If you need to obtain a power cord for a different country/region, you should purchase a power cord that is approved for use in that country/region.
The power cord must be rated for the product and for the voltage and current marked on the product's electrical ratings label.
The voltage and current rating of the cord should be greater than the voltage and current rating marked on the product.
If you have questions about the type of power cord to use, contact your HP-authorized service provider.
A power cord should be routed so that it is not likely to be walked on or pinched by items placed upon it or against it.
Particular attention should be paid to the plug, electrical outlet, and the point where the cord exits from the product.
1helpful
Neighbor mowed the extension cord and mower won't start
Check the cord has been properly replaced. Check circuit with a meter (NOT connected to mains) The live pin on plug should connect to live pin on motor switch etc. (need to take off cover on switch unit)
Cutting through the cord should not have damaged the mower.
4helpful
How do you connect the LG DLEX5101V Dryer to the electrical outlet on the wall if there is no cord to plug in?
There are a couple of types of plugs in homes - and the dryer manufacturer use this excuse to not ship a cord with the dryer - profiting that much more. You'll need to purchase a cord set for your dryer. Assuming you live in the U.S., that means you need a 30 amp 240 volt cord. That's easy enough, but it does get harder.
Most homes have an outlet that has three slots in it - like the one below:
A 240 volt, 30 amp, 3 wire dryer plug.
New homes have a safer, 240 volt 30amp 4 wire plug. They look like the one below:
A 240 volt, 30 amp, 4 wire dryer plug.
The code states that when a dryer is purchased it should be connected via a 4 wire cord. This means if you have the older, 3 wire outlet - it will have to be changed along with the entire length of cable between the electrical panel and the outlet (the new outlet needs a 4 wire cable - the older plug was supplied by a 3 wire cable).
Those are the rules. Many people opt to purchase the older 3 wire cords so that they can connect directly to the 3 wire outlet already installed in their home. As an electrician, I have to caution you on doing that. It is a violation of the electrical code as it has been identified as an unsafe condition. The code hopes to rectify this by slowly requiring new dryers to be wired with 4 wire cords and making the homeowner upgrade the old 3 wire outlet to a newer, safer 4 wire outlet. Of course, no one will come to see what you had and if you changed it, etc.
Mose hardware stores, Home Depot, Lowes, etc. sell these cords for under $20. Make sure you choose a 30 amp dryer cord - and not the similar looking but thicker 50 amp stove or range cord.
I hope this helps & good luck! Please rate my reply.
Mar 22, 2011 • LG Dryers
DOES A GE ELECTRIC DRYER MODEL # PSKP333EBWW COME WITH A 3 PRONG PLUG (115V) [email protected]
Hello, W/D here.
Dryers do not come with a cord. Most homeowners purchase their cord at the time of dryer purchase, based on their type of receptacle at home.
Best regards, --W/D--
I would like to change the electrical plug on my dryer
The outlet or the cord? You can purchase 3 or 4 prong cords at any Home improvement store. There is usually an extra screw at the terminal block for just that.
Need to order a cord to plug into my pc from camera
Look for a mini USB to regular USB cord at your local electronics store. These are generic cords - you shouldn't need to purchase a GE-branded one.
2helpful
How do I replace the electric cord for my Simplicity Shadow Vacuum cleaner model S13L? It's a canister cleaner.
Since the problem was with the plug on the electric cord, I replaced the plug, I cut the old plug, peel off the plastic cover on the cord, they were two wires, black & white, I purchased a new plug in a Home center, attach the wires to the new plug and it works just beautiful now, it was a two prong plug, which made it easier to fix.
6helpful
2answers
Was given GE PLL 3-5819A but need electrical cord
look at the back where it plugs in to see if its a 3 or 2 pin plug adaptor . then go to radio shack and buy one .
1helpful
Electrical cord
Power cords for Ranges and Dryers are not included with the appliance. You will have to note what type of plug receptacle you will be plugging into to ensure the cord you purchase will match the receptacle. All major home improvement centers carry all the standard cordsets.
Please close this ticket with a 'FixYa'. Thank you
Regards
reg501
Top Technique Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Technique Home Expert? Answer questions, earn points and help others
