Question about Motorola Mobility HS850 Consumer Headset
Pairing can't get the hs850 to pair with the v360 cellphone. HELP!
Re: pairing
Try pairing to another phone then back to yours..worked for mine after a day of messin and researching
Posted on Dec 03, 2007
0 characters
3 Points
The pairing light on my HS850 soes not come on?
You have to start with the boom closed and press the large button with the phone symbol until the blue light comes on, then open the boom before the light goes out and you should be able to pair it with your phone.
Feb 26, 2010 | Motorola Mobility HS850 Consumer Headset
Having problems pairing
How to pair a Motorola HS850 bluetooth headset How to place a Motorola HS 850 bluetooth headset into paring mode:
  1. Close the boom to turn the unit off.
  2. Hold down the call button until the blue light comes on.
  3. While holding down the call button, swing the boom open.
The headset is now in pairing mode, and you can search for it using your phone. When it asks for a PIN, use 0000.
Apr 12, 2009 | Motorola Mobility Universal Wireless...
Pairing a motorola n136 with a lg vx5500
your phone probably is not capable of syncing into that kind of blue tooth, if not go see your cellphone dealers store they will help you.
Jan 09, 2009 | Motorola Mobility HS850 Consumer Headset
I've lost my pairing code how can I get another on, or is there a
From the Motorola Website:
The default pin code or passkey for Motorola Bluetooth accessories products is 0000 and cannot be changed.
This should work for you, but if it doesn't you'll to contact Motorola
Dec 05, 2008 | Motorola Mobility HS850 Consumer Headset
To all with problems with bluetooth pairing.when you push button to turn on bluetooth headset ,hold button until steady light stays lit,then put phone in pairing mode,when ask for passcode enter 0000,which is the standard code for pairing bluetooth.
Mar 27, 2008 | Motorola Mobility HS850 Consumer Headset
Can't get the HS850 to pair with my blackberry
Device is not bad blackberry has a compatibilty issue with this headset try plantronics brand go to
Jan 08, 2008 | Motorola Mobility HS850 Consumer Headset
HS850 Signal Light Wont stay on to be able to pair w/ V3 razr
When I paired my headset to my Blackberry - I had to do the following... Set my phone into the pairing mode.. quickly press button on HS850 and when blue light comes on, hold button and open boom - It has worked this way several times for me.
Aug 14, 2007 | Motorola Mobility HS850 Consumer Headset
Pairing Motorola RAZR with the HS850
No, living outside of your cellular "home area" has nothing to do with the bluetooth pairing. You're problem is a common problem. Lots people have this problem you are not alone. So, here is what I suggest. 1. Make sure both the headset and the phone are fully charged. 2. Delete the "device" from your phone. I mean precisely that. Go into you cell phone's bluetooth settings and erase your "HS850" from it. 3. Try re-pairing it. Put the phone and the headset in pairing mode and allow it to sync. This should do it. I always works for me. You usually only need to pair once and every time you use the headset all you should have to do is connect it. I hope this works for you. Good Luck.
Aug 02, 2007 | Motorola Mobility HS850 Consumer Headset
Motorola Mobility HS850 Consumer Headset Logo
Top Motorola Mobility Headsets Experts
Chris Hunt
Are you a Motorola Mobility Headset Expert? Answer questions, earn points and help others
