Try to blow your nose whenever you feel stuffy or runny to expel all the nasty stuff. Drink lots of tea (herbal or lemon with honey recommended) or hot drinks along with juices rich in vitamins.
This will help to kill of the source of the problem if this is a common or head cold. This method helped me feel less horrible and function more human again.
sounds as though it may be a column stalk issue if all these functions are on a column stalk it may have become faulty.
It the light switch for main/dip beam is discrete may be a BCM or other electrical fault.
The first is the most likely but, as column stalks may cost a lot of cash, have a competent auto electrician take a look first
If you mean the illumination lights on the dashboard stay on as well as the tail lights even when the light switch on the turn signal stalk is turned off then it may be the turn signal/light switch. you can unplug this switch and if the lights turn off this is your most likely cause. If not you will need to get a wiring diagram to further diagnose the problem.
Do you mean it won't automatically switch off after you turn, or do you mean it stays on, either flashing or just permanently on?
If it's the 1st one "doesn't automatically switch off after turning" it sounds like your turn signal stalk is broken & needs replacing.
If it's a case of the light just continuing to flash or stay on well then it could still be your signal stalk or the relay which times the lights to flash on & off.
All these bits can be purchased for little money on eBay
It is probably where the seat belt plugs in (Stalk) This will cause both lights as it is part of the SRS (Suplimental Restraint System). Start by looking under the drivers seat at the wire from the seat belt stalk & look for any damage to the wireing. Then check passanger side. It is normaly drivers side cause that is the seat that gets mved most. All SRS plugs should be yellow for identification
