Question about Logitech Marble Mouse Trackball
Change default button settings
I have a new Vista computer and I want to change the default settings on my marble mouse. This was fine on my Win 2000 system, but I can't figure how to do this in Vista Any ideas?
  • 8,637 Answers
Re: Change default button settings
Normal 0 Go to Control Panel and click on the Mouse icon. When the window opens showing the mouse, select the button you want to change and click on the drop down and set as desired.
Hope this helps. Bud
Posted on Jan 20, 2009
0 characters
3 Points
Right mouse button closes window
1) Can you try the mouse in a different machine? Does it do the same thing?
2) Check your settings in 'SetPoint' software, or go to your Control Panel and check your mouse settings - you may have accidentally changed the settings for your mouse keys somehow.
3) Download the latest drivers for your mouse and re-install. (In downloads section)
Nov 05, 2013 | Logitech Trackman Marble Wheel Trackball
Poor battery life with Logitech V450 cordless mouse
The problem is likely in the software (drivers), assuming that you are using quality batteries (those manufacturer's specs are based on top-shelf, fresh-off-the-truck alkaline batteries).
When you replaced the first set of batteries, the absence of a mouse caused the receiver to search, and having found none, it's common for the driver to reset to default settings.
The Logitech driver is the first suspect; go to Control Panel, Logitech Mouse...Driver Properties... Look for the "Auto-off" setting, and change it to 10-30 mins (or the lowest setting you can live with)...What you're looking for is the driver that has reverted to "never" in the auto-off setting...and if that isn't changed here, then it was Windows.
You'll have to tunnel a bit to get to this one, but it's not as hard as it looks.
The second suspect is the Windows driver; For Win XP, from the Control Panel, go to "Mouse"...or for Win-7 go to Control Panel- Devices and Printers, Hardware- and choose "Mouse" from the text links.
From the new menu, choose the "hardware" tab, and the "Properties" button near the bottom.
The new menu page has a text area that states "This device is working properly", and under that is a button labeled "Change Settings"...Click it.
Click the radio button labeled "Allow the computer to turn off this device to save power"...and you're done.
Click the "OK" buttons to close the menu sets.
Apr 18, 2010 | Logitech V450 Nano Cordless Laser Mouse
When I click the left button, my v450 nano clicks the right, and when I click the right button, it didnt anything. I use Windows 7. I tested it with Vista and XP, and many computers, and I replaced the...
hello, it sounds like your click buttons are inverted in settings, Try this: go to control panel, double click the mouse icon, select the "Buttons" tab, check settings. These settings are usually in this order:
Left button = Click (default)
Right button = Right-Click (default)
Wheel Button = Instant Viewer (default)
make sure your right click and left click settings are correct there if not you can change them by click on the dropp down and selecting appropriate setting you prefer. You will also see a option of "Restore Default" a quick way to reset to default settings.
I hope this helps, good luck.
amar Sondhi
Dec 15, 2009 | Logitech V450 Nano Cordless Laser Mouse
Right mouse button not working
usually every time a mouse is experiencing this kind of problem its already defective sorry to tell its better you change your mouse to a new one.
Sep 16, 2009 | Logitech Marble Mouse PS2/USB MSLO904360
Greetings: I'm moving a marble mouse to a new computer. Previous setup had left small button perform the "back" function. I cannot remember how I programmed this. Please help...!
I believe you would have programmed the buttons with the driver software that SHOULD have come with the mouse. That would be your best bet. Look to see if the drivers installed a utility to program that mouse buttons.
Jul 06, 2009 | Logitech Marble Mouse Trackball
Buttons dont work like they did
You can try accessing mouse properties in Control Panel and check, change the button configuration on the button tab.
To access mouse properties, click Start, then Control Panel, double click Mouse, then the buttons tab.
Feb 18, 2009 | Logitech Optical Marble Mouse USB PS/2
MX3200 Mouse Won't Work
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Jan 04, 2009 | Logitech Cordless Desktop MX3200 Laser...
Logitech Link for Marble Mouse Software Update 1-28-2008
Yes, its not just for the Marble Mouse, it will work with any Logitech device that uses the SetPoint software.
But thanks for that update, much appreciated
May 03, 2008 | Logitech Marble Mouse PS2/USB MSLO904360
Marble Mouse Preferences Problem
Try Normal 0 Go to Control Panel and click on the Mouse icon. When the window opens showing the mouse, select the button you want to change and click on the drop down and set as desired.
Oct 28, 2007 | Logitech Marble Mouse PS2/USB MSLO904360
Logitech Marble Mouse Trackball Logo
79 people viewed this question
Top Logitech Keyboards & Mice Experts
micky dee
Are you a Logitech Keyboard and Mice Expert? Answer questions, earn points and help others
