This is the REAL working method of manually resetting Canon ip1880 - ip 1980.
1. Unplug the POWER cord. 2. Press & hold the power button. 3. Connect the power cord WHILE holding the power button. 4. Keep on holding the power button for about 30 seconds. 5. Release the power button. The printer should be turned off. 6. Turn the printer on and that's it!
NOTE: You have to do this every time you turn on your printer. Or you will get the waste pad full error.
Manual reset for canon pixma iP 1980 it easy and like resetting canon ip 1880.If found problem in your printer canon iP 1980 maybe this methode can be use. This reset manual be used to reset waste ink counter in canon pixma iP 1980.
Here how :
Turn on your printer Canon Pixma iP1980
now Press and hold Resume button for two (2) minutes and then release Resume button.
Turn off the printer and turn on again, the Printer will back to normal again.
Here how :
I put the new ip1980 ink cartridge (CL-41) in, and started the print - it does not work. When I...
(More)
I put the new ip1980 ink cartridge (CL-41) in, and started the print - it does not work. When I checked the ink on the menu, it showed that the ink level is zero
I have replaced both cartridges, but the yellow light keeps flashing and a window keeps appearing...
(More)
I have replaced both cartridges, but the yellow light keeps flashing and a window keeps appearing saying that they are incorrectly installed and I must cancel printing. They are not incorrectly installed, but printer will not print or perform maintenance. I need a troubleshooting manual which tells me what to do when printer won't print and how to respond to windows which appear on screen. Why is troubleshooting manual not supplied with printer? On screen "help" is completely useless - it tells you what is wrong but not how to fix it!
ink cartridge replaced on pixma ip18oo 2 lights flashing above the ink cartridges amber and green...
(More)
INK CARTRIDGE REPLACED ON PIXMA IP18OO 2 LIGHTS FLASHING ABOVE THE INK CARTRIDGES AMBER AND GREEN SIMULTANEOUSLY. IT SAYS THERE IS AN ERROR AND TO TURN OF PRINTER AND BACK ON AGAIN BUT IT DOESNT WORK
