Lands Phones Logo
S
SHELLY Posted on May 28, 2015
MY HANDSET SAYS INITIALIZE AND WONT LET ME ANSWER CALLS
2 Related Answers
Anonymous
  • Posted on Mar 08, 2011
SOURCE: I have a 2 handset
The problem may be due to both your handsets operating on the same channel. To fix, try pressing and releasing the "chan/delete" button on one of the headsets. This will move it to the next available channel.
cnavarro
Carl Navarro
  • 2460 Answers
  • Posted on Jul 08, 2011
SOURCE: one phone handset will not
It needs to be put in the ICD group. By default, nobody is in ICD group 1. Adding the phone and giving a ring status to it, even if it's no ring, makes the light blink on incoming calls. If you have access to system programming it's program 622 and 623. If you don't, your dealer/installer will have to do it.
Carl
How do I forward my phone number on a Dect 6.0 cordless phone model 30524
Do you mean the GE DECT 6.0 30524 corded/cordless phone? For this landline telephone, you can switch a call from one handset to another (or the base) by using the Intercom feature. Press del/int on the handset or Int on the base and choose a handset number (use the CID +/ phonebook -) buttons (if multiple handsets are registered) or select base from the handset. Press Menu/OK to page the other handset or base. Once that device answers the incoming Intercom call, press and hold Del/Int or Int to create a conference call (both handsets or handset and base listening). Press Del/Int or Int to switch from the Intercom call back to the call on hold. Hang up on the first handset if the person on the second handset will continue to speak to the original caller alone. See pages 24-25 of the manual to see the directions. The direct link to the manual is currently https://www.101phones.com/pdf/ge/30524-user-guide-english-f.pdf .
For any landline phone, to forward a call to another phone number, you need to subscribe to a forwarding option with your telephone company. Check their information for initiating call forwarding.
If you have a different 30524 phone, please add a comment with the manufacturer.
I hope this helps.
Panasonic KX-TGD564 Link2cell call forwarding code
Have one of these bluetooth answering systems. they link to your cell phone to allow it to be used on cell headset mode instead of hunting for a handset. Handy but I have gone away from that after a year. The forwarding your are talking about is not initiated from the cell phone (I guess it could be) but from a cordless handset. And if properly paired, why do it? Your cell phone responds to the base and allows all functions. Answer, place calls etc. From the land line not your sell phone.
When answering mode is on I do not want to hear the ringing(4x) tones before going to answering.I've switched off the 'call screen' option. still I hear the ringing although not recording at least.
Just set the ringing volume to off.
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level. Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according to their individual settings
23helpful
2answers
How do i turn off the silent mode on a uniden phone, ive held down the # sign and nothings happening
Silent Mode
You can silence the ringers on the base and all handsets for a specific period of time; the answering system answers any incoming calls without playing anything through the speaker.
With the phone in standby, press and hold # on any handset. The phone prompts you to select the number of hours (1 - 9 or Always On) that you want it to stay in silent mode.
To confirm, press # or just wait about 5 seconds. The phone turns on the answering system and displays Silent Mode On on each handset.After the selected number of hours, the phone automatically exits silent mode. To exit silent mode manually, press and hold # again.
If the phone is in silent mode and you turn off the answering system, the phone exits silent mode.
Multihandset Features To use the features in this section, you need at least 2 handsets.
Your base supports a total of 12 cordless handsets: the one that came with the base and up to 11 DCX160 accessory handsets.You must register accessory handsets to the base before using them. (Handsets that came packaged with the base are already registered.)Handsets that aren't registered display a Not Registered message. For registration instructions, see p. 18, or see the accessory handset manual.If a handset was ever registered to a base, you must reset it before it can register to a new base; see p. 18, or see the accessory handset manual.Conference Calling
When an outside call comes in, two handsets can join in a conference call with the outside caller.
To join a call that's already in progress, just press Talk/flash or SpeSpeSpeaker.To leave the conference call, hang up normally; the other handset remains connected to the call.
1helpful
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
I have a Panasonic KX-TGA652 dual handset no answering machine. The problem I have is the 1st handset "the base set", doesn't seem to work properly, the 2nd handset works 100% fine. The problem is this,...
Id try the following in this order:
  1. Try swapping batteries with another set and see if the problem follows the battery
  2. Try re-registering the handset, they could of missed one at the factory. that is done by selecting menu->initial settings->register handset
If this doesn't work, then return for warranty/exchange. Mine seem to work great right out of the box.
the poodle guy!
I switched handsets and renamed them, but my calls are still going to my old handset. How do I fix this issue?
You will need to se-register the handsets you are getting rid of...on the base unit go to initial settings-registration-deregister handset. Deregister the handset #'s you are trying to swap (the number is just left of the name on the handset display). Then register the 2 new handsets (on handset: menu-initial settings-regitration) and on base menu #123. Follow instructions on screen to complete registration. This should activate your 2 new hansets and de-commission the old ones.
8helpful
2answers
How do access my panasonic kx-tga101s voicmail ?
First of all; Do you have the user guide manual? If not you can download it for free at...www.static.tigerdirect.com/pdf/panasonic_kxtg10325_manual.pdf
This manual addresses handset kx-tga 101s.
The unit lets you know when you have new voice mail, in the following ways; "new voice mail" is displayed on the handset; The message indicator, on the handset, flashes slowly if message alert is on. In order to listen to your voice mail messages, you must dial the telephone service providers voice mail access number. If the handset still indicates messages that have been listened to turn it off by pressing and holding "CLEAR" until handset beeps.
Do you subscribe to a service package that includes voice mail? If so, to use that service turn off the answering machine; And use the instructions provided by your service provider. If you want to use the answering system, call your service provider to deactivate your voice mail service. If service provider cannot do this then set the answering system "RING COUNT" so the system answers calls before voice mail. Check with your service provider to find out what the ring count of the voice mail service is , then make the answering system ring count so it answers first.
Let me know if this answered your question.
FixYa [email protected]
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
2helpful
2answers
Panasonic KX TG9331 no link to base Even standing next to the base, I cannot answer the call. Sometimes repeated pressing of the talk button lets me talk. Also, switching to speaker phone sometimes drops...
Sounds like a defective handset or base unit. Unplug the base unit from power and the telephone jack. Leave unplugged for 1 minute, this sometimes helps the phone to reset from a problem. Unplug the battery from the handset and plug back in after a minute also to help reset. Place your handset in the base unit for about 1 minute to allow the handset to link up with the base unit. If this doesn't work you may have a defective phone. Contact Panasonic support for further information if this does not work.
Top NEC Lands Phones Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
RAJA NADEEM AKHTER
RAJA NADEEM AKHTER
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
