Manitowoc I-1000 Indigo Remote Ice Machine 960 LBS Logo
A
Allan cornish Posted on May 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The lid keeps coming up and the red lights are on
Marat Brikov
Level 3:
Director Badge:
Uploaded 100 video answers.
  • Manitowoc Master 518 Answers
  • Posted on Aug 23, 2015
Marat Brikov
Manitowoc Master
Level 3:
Director Badge:
Answers
518
Questions
0
Helped
324532
Points
3123
What lid? and what red light? and how many times red light blinks?
Jay Plesset
Level 3:
  • Master 2,942 Answers
  • Posted on May 28, 2015
Jay Plesset
Master
Level 3:
Answers
2942
Questions
Helped
668521
Points
9879
Unfortunately, Fixya can't answer every question. We're purely a volunteer effort, and if nobody is familiar with your Ice Machine, then nobody answers. I would certainly contact the place you got it.
Won,t work just flashing blue light
Cycle light flashes, but machine wont start - Kenmore Elite ...
https://www.ifixit.com/.../Cycle+light+flashes,+but+machine+wont+...
iFixitThe Kenmore Elite HE3 is a washing machine by Kenmore. ... Whatever cycle I choose, the light just flashes and holding the start button ... I don't seem to have a black pin....the normal wash button just keeps flashing and won't let me start or .
The good ol' Whirlpool Lid Lock Flashing Light Problem - ApplianceBlog
www.applianceblog.com/.../42456-The-good-ol-Whirlpool-Lid-Lock-Fl...
Dec 11, 2013 - 10 posts - ‎3 authors Red Lid Lock light flashing intermittently when you try to start a cycle. ... Mode -- Lid Lock won't work, nor will anything that requires the lid to ... Once the lid has locked the second time, the washer ... shuts down with the lid lock blinking; go back into diagnostic codes and look for shifter or speed sensor errors ...
Blinking lid locked light and green sensor light on machine won't start cycle
Red Lid Lock light flashing intermittently when you try to start a cycle. ... I'm going to post what SENSING does first, then you will need to locate your tech. ... start with thelid lock on and blinking, or the unit will not start and spin. FIXED Sense light on light humming noise won't start ...
Aug 9, 2015
Whirlpool WTW4950XW not working
Nov 2, 2013
Stacked GE washer/dryer lights Blinking doeent start at ...
Feb 20, 2012
More results from www.applianceblog.com
Washer Sensing led (Green) on with the lid locking led (Red ...
www.shopyourway.com > Manage My Life > Questions
... this: Sensing led (Green) on, the lid locking led (Red) blinking with a clicking noise ... red led light goes off green led light stays on and the washer does not start.
1helpful
Fisher paykel GWL15 96200B lid will not lock
Change lid lock its the lowest cost part if not lid lock main PCB
is bad High dollar part I would say it is the lid lock they go bad a lot
on many washers
WASHER ... COMES ON GREEN SENSING LIGHT STAYS ON START'S TO FILL CLICK'S OFF RED DOOR LIGHT LOCK LIGHT COMES ON STAY'S BLINKING
Thank you first person that has provided a model number sounds like you already changed the lid lock assembly if you did you know how to get the top up inside the front panel is a tech sheet it will tell you how to place the unit into diagnostic and read the lights for an error code recheck your connection at the control board a flashing lid lock would should give and F5E1 or F5E2 error code also check the alinement of the tab on the lid where it goes into the lock assembly should be a smooth transition
1helpful
Maytag Washer Lid lock light
Its normal for the machine to cycle the lock before starting its cycle. I'm assuming your machine is a bravos style.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
1helpful
2answers
I own the Saeco Vienna Superautomatica which I have enjoyed tremendously!!! Unfortunately I made a cup of coffee yesterday and heard a "clunk" then the red light came on. I turned off the machine and...
You have not mention anything about the group. Did you try to take it out and put back again. If the problem insist this mean from your description that the clunk is from group motor gears or even the motor gear it self.
In this case the machine must be desasemble in order to find out which part brocken.
If you can remove group and put back again and nothing happents then switch it of and proceed as above since it might just one gear and by replace it the machine will be ok again. However if you try something more then their is a chance to burn the motor also and the cost for repairing it will high and it will be better to thing about a replacement since spare parts are very high compare to a complete machine that might get it from special offers.
You revice all above and if you need any further asistant you can coment back.
ood luck
What can I do if the drainage red light comes on?
In most cases, Its simply the lid switch that has gone bad.
Put your washer on Spin cycle and look for the little plastic peice on your lid that goes into a small opening, if you have this then verify its working by pushing a small screwdriver in the hole, pressing it down.
The washer needs to verify that the lid is closed before it will go into spin mode (Safety for peoplesw hands etc).
If you dont see this then you may have a magnic type switch or one built into the lid itself.
Most local appliance parts stores have this part with a model and make of the washer.
Good Luck!
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
7helpful
My Epson Perfection 4990 indicator light is flashing red shortly after the scanner is turned on. The manual says that the light tube needs replacing. How do I do this or is it a professional repair?
I had the same problem and first checked the instructions in the Epson manual on the red flashing problem, read the following pdfs: Indicator light or problems
I saw the fluorescent lamp come on for a second before the indicator light started to flash red, so I knew that the lamp was ok and did not need to be replaced. Try this turn off the scanner and try unplugging the transparency lid from the back of the scanner, turn on the scanner and see if the light goes back to green. My issue turned out the be the mechanism inside the transparency lid, I kind of heard an awkward noise when I turned on the scanner, but thought it was coming from the base, I rlocked and unlocked the transportaion lock on both the base and lid, to see if that would fix it but it turned out it was coming from the lid, where there is also moving parts inside using a belt and wheels. On the end wheel closest to the front, the 2 little plastic pegs that hold down the square metal plate with wheel broke off, I could hear them inside when I lightly shook the lid, anyways I opened up the lid by removing the 5 screws and you need a screwdriver to put in each of the little openings around the edge to pry open the lid. I removed the belt and metal plate, watch out there is a spring attached to it, don;t forget how this part works when you put it back on, I found both of the little broken pegs and glued them back on with a strong plastic epoxy glue that I bought at Ace Hardware, I let that dry for 24 hours and then put the metal plate and wheel on then put the belt around the wheel, and now everything works fine.
Top Manitowoc Kitchen Appliances - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Tesfay
Tesfay
Are you a Manitowoc Kitchen Appliances - Other Expert? Answer questions, earn points and help others
