Question about Palm Tungsten E2 Handheld
I can't get my Tungsten e2 to turn on.
I'm charging it as we speak and I've tried to reset . It just isnt turning on or doing anything. help!
  • 1 more comment
  • MDMAGGIE Nov 21, 2007
    Palm was working fine was fully charged, turned it off and now it won't turn on. Have tried reset as well as hard reset and nothing happens.
  • Anonymous Nov 27, 2007
    Same problem. Tungsten E2 won't turn on, charge, or respond at all. Reset, hard reset did nothing.
  • JoPT Dec 09, 2007
    My Tungsten E2 just wouldn't turn on one day. Recharged battery, went to online Palm tech support and followed all troubleshooting tips, tried phone support ... but it's still dead at less than a year old.
Open up casing to reveal battery. disconnect then reconnect battery connection to mother board.
Posted on Dec 10, 2007
My palm tungsten e2 does not power on at all? what is the solution. i tried soft reset. it did not work out.
It could be the battery. may be the charger is stuck ,did you Connect the E2 to the charger then soft reset ?this should reset the charging circuit on the Palm.after that Let it connected to the power adapter for a good 2 hours. After that, disconnect the Palm and see if it will turn on. If not, then you need to get a replacement battery for your Palm.hpe this helps.pls do let me know thanks
Jan 12, 2010 | Palm Tungsten E2 Handheld
Will not turn on
It's possible that the battery can no longer hold a charge anymore.
Check with Palm to see if there is a replacement available.
It should work if you have a car charger on it while using it.
Mar 31, 2009 | Palm Tungsten E2 Handheld
My Palm Tungsten E2 Handheld won't turn on
try to push the reset button (small hole) on the back of the device. You may need to perform a Hard Reset (returns device to factory settings).
Mar 01, 2009 | Palm Tungsten E2 (Multilingual) Handheld
Tungsten E2 wont power on
Turn it on pressing the reset at the same time or take out battery and unplug/plug the battery. Your battery may have died. If this is helpful, post as such. If it is a fixya, post as such. I had an E2, can tell you alot about it. TY
Jan 23, 2009 | Palm Tungsten E2 Handheld
Palm tungsten e2 will not turn on, replaced batttery,
Plug you E2 into your PC for 8 hours to slow charge. Press reset button on back and later in life your E2 will come on by itself.
Dec 23, 2008 | Palm Tungsten E2 Handheld
Palm will not turn on
have you tried a hard reset?
Todo a hard reset, First press and hold the power button, while holding the power button use the tip of the stylus to gently press and release the reset button. wait for the logo to appear then release the power button.
when you see the message that warns you about erasing all of the info on your hand held press up on the 5way navigator to finish the reset
Dec 21, 2008 | Palm Tungsten E2 Handheld
Tungsten E2 will not power on
The Tungsten is an excellent PDA
You do have to be careful with how you handle it if you've dropped it too many times or set it down too hard or whatever something inside will get cracked or disconnected.
So you may want to open it up (personally I use a really small screwdriver but there is a kit for 9.95 on that comes with a Shim like tool that is really useful for splitting the Tungsten open because its not easy getting it open and closed)any way open the back up and make sure everything is connected and clean especially the connectors to the screen, battery and USB/charging plugs. You may also need to try charging it overnight. If you haven't run the PDA in a while its going to read a full charge regardless of how much of a charge its actually holding. Also, there are alot of other places to get A PDA repaired do a little research and find a place near you that will repair a PDA. An official Palm repair is almost always going to cost you more than anywhere else.
Jun 06, 2008 | Palm Tungsten E2 Handheld
Palm tungsten E2
Does anything happen when you try to turn it on? Does anything respond or light up?
Jan 19, 2008 | Palm Tungsten E2 Handheld
My Palm Tungsten E2 does not turn on.
Have you tried doing a soft reset? To do a soft reset, use the tip of the stylus to gently press the reset button inside the hole on the back panel of your handheld.
Jan 09, 2008 | Palm Tungsten E2 Handheld
Tungsten E2
Have you tried pushing the reset button on back to see if it comes on?
Nov 26, 2007 | Palm Tungsten E2 (Multilingual) Handheld
Palm Tungsten E2 Handheld Logo
199 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
