These are pressed in. You have to press the hub out first(center part), then there is a C clip that has to be removed to press the bearing out. If you don't have a 20 ton press take it to a shop. Costs about$30.00
Removal & InstallationFrontTo Remove:
The front wheel bearings are not serviced separately. If the front wheel bearings are defective, the hub and bearing assembly must be replaced.
Before servicing the vehicle, refer to the precautions in the beginning of this section.
Lubricate the threads on the halfshaft with clean engine oil.
Remove or disconnect the following:
Front wheels
Halfshaft hub nut
Caliper from the steering knuckle
WARNING DO NOT allow the brake hose to support the weight of the caliper.
Brake rotor
Anti-lock Brake System (ABS) sensor from the backing plate
Hub and bearing assembly from the backing plate
Hub and bearing assembly from the halfshaft
To Install:
Exploded view of the front hub mounting and related components
Install or connect the following:
Hub and bearing assembly onto the halfshaft
Hub and bearing assembly to the backing plate. Torque the 3 bolts alternately and evenly to 70 ft. lbs. (95 Nm).
ABS sensor
Brake rotor
Caliper on the steering knuckle.
Halfshaft nut. Torque it to 118 ft. lbs. (160 Nm).
Front wheel. Torque the nuts to 100 ft. lbs. (140 Nm).
trywww.autozone.com to see if they have your car listed for diagrams pictures and step by step instructions if your car is not listed then try your local library they have all the car manuals and even copy them for you
