Question about iiyama Pro Lite 38a Monitor
Screen settings wont save
I have a iiyama pro lite 38a. Since i have shanged my resolution for more pixels and a better picture i have had problems adjusting the screen settings. Using the buttons on the monitor i have tried to adjust the screen position and brightness etc, but there is no 'save' option, and as soon as the menu disappears, my settings are lost and the screen is once again off centre and a bit bright.
How do i save settings in this menu?
Re: Screen settings wont save
To solve the problem of left-alignment, try setting the output of your computer to 75Hz. See for how to do this.
Posted on Feb 04, 2011
0 characters
3 Points
Screen Resolutions My resolutions changed to very small, when I clicked on the monitor.
Your operating system?
For Windows XP,
  • Right click in an open area on the desktop.
  • On the window that opens select properties.This opens the Display Properties window.
  • Click on settings.
  • On the screen resolution option,set to around 800x600 pixels.
  • Click O.K to save.
For Windows 7,
  • Click on the start button.
  • Click on the control panel and under Appearance and Personalization,select Adjust screen resolution.
  • On the list next to Resolution,move the slider to the resolution you want.e.g 800x600 pixels.
  • Click on keep to save the changes.
For Windows Vista,
  • Click on start button.
  • Click on the control panel and then on Appearance and Personalization.
  • Click on Personalization and then on Display settings.
  • Under Resolution,select the resolution you want.
  • Click Apply to save the changes.
Hope this helps.Thanks!
Please rate this answer.
Oct 28, 2011 | Computer Monitors
Windows 7 doesn't recognize my iiyama Vision Master Pro 450 Monitor, what to do?
My Iiyama Vision Master Pro 450 works with Windows 7 when connected with a VGA video cable that has 5 BNC RGB connectors that attach to the back of the Iiyama monitor. No driver install was needed; Windows 7 shows my Iiyama monitor as a "Generic Non-PnP Monitor" with 1024x768 resolution.
Jan 13, 2011 | iiyama Vision Master Pro 450 Monitor
19" Iiyama HM903DT A Vision Master Pro 454 not detected
Try downloading and installing drivers.
I found some here:
Nov 10, 2009 | iiyama Vision Master Pro 454 19" CRT...
hi how old is ur monitor? is it a old type or a any case i would not open it ....if its a old monitor put it in the trash......and get a new one.....other wise if u have lcd get it checked out .....
Jul 03, 2009 | iiyama Pro Lite 38a Monitor
Hi Sammy7!!
I have such iiyama AS4636D monitor. In this day purchase.
I have such problem with you.
My solution:
Desktop pc and lcd power off (230VAC or 110VAC)
Power on lcd, after early desktop pc.
This moment, when running the pc booting, press and hold you the " + " button.
In this moment come in one blue screen. May be running on the sreen short message: check or select input mode: VGA DVI 1 2 . Select your correct cable connection type.
Have a nice day! and happy new year!
Lajos from Hungary
Dec 13, 2008 | iiyama Pro Lite AS4636D (Black) 18.1 in....
Iiyama Pro 452 clicking sound during start-up
Your CRT Monitor will fail soon. The clicking sound is coming from your CRT's power circuit.
Make plans now to replace it. This problem is known to be a fire hazard in some cases. So, better safe than sorry.
Sorry for the bad news.
Hope this was helpful.
May 21, 2008 | iiyama Vision Master Pro 454 19" CRT...
Iiyama Pro Lite E485S
do exactly this:
- power off monitor with the POWER button!
- unplug power cord
- hold -/+ and keep holding them when briefly pressing POWER to get the monitor back on
- press menu
You are now in the service menu. Adjust the settings as you like.
- press EXIT
- power off monitor with button
- power on monitor with button
- AUTO SETUP... will be performed
- re-adjust brightness/contrast
edwin (rdam nl)
Apr 16, 2008 | iiyama Pro Lite 38a Monitor
Monitor speakers
i do not know that but if it run under windows xp you can try in this
way . if you click on windows start with mouse you have to reach
control panel and after that there is (in classic diplay ) sound and
peripherals , there yopu can try to check for the speakers if they are
connected or not - i hope it was correct  - delfo
Mar 21, 2008 | iiyama Pro Lite 38a Monitor
PC monitor wont come on.
Check that the power cord is fully plugged in first.
It is probably the inverter board inside the monitor.
(if the screen does properly display ever then it is not the screen)
It CAN be fixed but I do not suggest anyone open up a monitor (LCD or CRT) who is not "technically inclined."
If you really want to fix this particular one then take it to a local tech and get an estimate first. If it's almost as much as a new monitor then buy a new one.
Mar 14, 2008 | iiyama ProLite E434S 17" LCD Monitor
iiyama Pro Lite 38a Monitor Logo
213 people viewed this question
Top iiyama Computer Monitors Experts
William Miller
William Miller
Ed Mac
Are you an iiyama Computer Monitor Expert? Answer questions, earn points and help others
