Plumbing Logo
C
Cory Corigliano Posted on May 28, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why can't I get the pump to prime and pump?
Pump worked fine last year. Put it away for the winter now I have primed it various ways and I cannot get it to pump. Could the pump impeller be bad?
Mike Tellegen
Level 3:
  • Master 1,631 Answers
  • Posted on May 28, 2015
Mike Tellegen
Master
Level 3:
Answers
1631
Questions
Helped
1012371
Points
5840
Replace ANY orings, gaskets, or seals in front of pump. The Suction/Inlet side.
Replace the Shaft Seal, that is the one between the motor and the Wet End. Right at the impeller.
check for wear or slippage, or breakage of the impeller.
good luck.
How to clean debris from impeller? Pump is not drawing water from the skimmer/pool .... I'm hoping the impeller is clogged and not something more serious like a shot motor.
There are normally 4 to 6 bolts around the outside connecting the wet end from the dry end. Undo those bolts and the front of pump should come away. Then you should be able to see impeller. Using a piece of wire poke it through each slot of the impeller to clear the blockage. Then put back together again. Remember to prime the pump
Jan 30, 2017 • Pool & Spa
Error after short prime cycle
AIR LEAK IN SUCTION LINE. PUT A GARDEN HOSE WITH A RAG AROUND IT TO BACKFEED FROM INTAKE IN POOL. WITH PUMP "OFF" TO LOCATE BREECH IN LINE.
90HP Yamaha won't turn over
It sounds like you have a air line busted somewhere i had one of my outboards do that it wouldnt prime for anything so i ran everything down checked the fuel pump and cleaned that out tore apart the carbs cleaned them bought brand new fuel hose still scratching my head i took off the air lines for the carbs and put new ones worked like a champ
Aug 22, 2012 • Boating
I have a 1 1/2 hp Flotect irregation pump for my
there is a drain plug that can be unscrewed , sometimes they can fall out or get lost, if this happens you will not be able to prime. Also when you stored it for the winter, if you didn't drain it all the way did you store it some where the water inside the pump could of froze and broke something inside? When pumps go bad they just stop working like this. IF there is a leak under ground in the pipe it will not build pressure and prime. Some times you need to check the main control valve to make sure its opening. you can try taking a hose and filling the sprinkler system at a sprinkler head then turning the pump on.
Apr 26, 2010 • Plumbing
2helpful
2answers
How do you prime a sta-rite mse-6 deep well pump?
Take the pressure guage off and pour water in the hole untill it fills the pump, then screw the guage back on and cranck it up. You may have to do this a few times depending on how deep in the grownd the water is.
1helpful
Flotec pump takes long time to pressure up. Has worked fine for ~15 years + but noticed the last month or so it runs and runs even after water use is shut off. It's like it's half the pump it use to be. We...
This could be a problem it the pump caused by freezing, check your drain plugs first to see if their cracked or loosened. They will quite often be made if a softer nylon that will crack first and drain pump in the fation of many fail safes. A place to try on-line for parts that may help is "Optimus Home" But I would check the plugs first.
Swimming pool pump wont drain above ground pool
you are clogging your impeller take a wet vac put hose your using for pump in pool put vac on end of hose to woods and turn on vac long enough to get a water flow and shut of vac it is slower but will save pump
03 malibu won't fire up right away, recently installed new sending unit, runs & idles fine, re-starts fine after short stops. Could the new fuel pump have a denser strainer & causing this? It takes...
I would be looking at fuel pump and the next question would be to check your fuel cap. Does it fail if you was to remove the fuel cap. You may be losing prime this way. If so the purge value in your fuel pump would be bad causing it to lose prime.
Lossing Prime
It's pulling in air very slowly from somewhere:
priming pot lid,
valve body tops,
valve handles,
pipe unions, --
check gaskets/o-rings-- replace defective ones, lubricate
tighten everything possible
Top Plumbing Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Plumbing Expert? Answer questions, earn points and help others
