What is the number of that IC. Let me see. Will try to get you one; if you're ready to spend. Gopakumar Gopalan Google
SOURCE: part help
the vertical o/p generic number stamped on the fron of the ic is "TDA8172" the sony part number is "8-759-980-58". good luck
SOURCE: Kv-36xbr800
Hiii...
My version is :
For safety reason you should replaced them ( Horizontal ic,Vertical ic, Deflection ic) and olso all the big capasitor nearest the ic....that's my version....if you have big budget for it....he..he....
Thank's
[Vrya]
SOURCE: regulator ic of sony tv kv-g21c1
I am not familiar with the particular model of Sony TV that you have. I can answer genericaly:
There are a number of voltage regulators typicaly used on TV sets. These are usualy IC devices, or a complete descrete circuit. The purpose of these are to regulate voltages that are used to operate various circuits. Most sets can typicaly have anywhere from about five to maybe even a dozen or more throughout the set, depending on the sophistication of the model.
The regulators, like any part in the set can fail with age and use. Sometimes they are damaged from other components failing, or when a regulator fails, it can damage the circuit areas that it is suppying. When the set is being service, the tech must check for other failed parts.
Jerry G.
SOURCE: sony color TV model kv-c29 11d blown power supply ic and transist
There should be circuit designations printed on the PC board. Without those, there are too many possibilities to give you anything useful. Can you provide those please?
Thanks,
Dan
