Question about Creative Labs ZEN Vision:M Digital Media Player
HOW DO I FIX MY ZENITH TV HAS NO IMAGE
Voice works but there is no image
IMAGE STAYS ON FOR AN LONG TIME
Sounds possibly like image retention. If you watch the same channels often any recurring text, logos, or graphics, especially white colored, can ghost on the screen.(playing the same videogame for a long period can also have the same effect) Watching other programs or channels will cause the ghosting to disappear.
To prevent image retention you need to activate the TVs anti image retention mode(Called ISM Method). On Zenith and LG (the manufacturer of Zenith T
s) plasma TVs open the TVs menu, select the Option section (picture of a briefcase with a wrench). Select ISM Method and change it to Orbiter, this is reccomended if you watch programs or channels (or play videogames) that have still images for long periods of time. It moves the image a little every couple minutes.
If watching others channels or programs doesn't make the image disappear, change the ISM Method to either Color Wash or White Wash (don't use White Wash frequently, it over excites the plasma gas and can shorten the life of your TV if overused) for a few minutes and then return to Orbiter.
Oct 23, 2013 | Zenith Z60PV220 60-inch Plasma TV
Zenith TV has me seeing red.
The red gun in the picture tube itself is shorted on. You will have to replace the picture tube itself to fix the problem. Probably want to just buy a new set. Sorry!
Mar 16, 2010 | Zenith B25A10Z 25" TV
2 pictures image showing on screen trimed in read and yellow
Well - Good news - This is a convergence issue. Some how the Red's CRT's image has drifted off of where it should be of overlaying itself on top of the green and blue 'which make yellow by the way'.
If you contact a Zenith/LG Service center they may have a TV Tech that can come out and fix this issue. May be between $100 to $200 charge. Just guessing but this is fixable.
Blessings,
A/V Media Guy
Nov 20, 2009 | Zenith IQB50M90W 50" Rear Projection...
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Zenith R56W36 Image in 3D
This needs a special remote to get to the factory alignment screen.This is the part # for the remote ---#105-201m .
You really should call a good TV Tech on this one. They are a convergence nightmare for even a good Tech.
Jul 31, 2009 | Sony KP-57WS500 57" Rear Projection...
Image goes off screen
it requires a TV repair person to fix the internal problems.
Jul 08, 2008 | Zenith C27A24T 27" TV
TV has multiple images and flickers, images are not centered and different sizes? What is wrong?
Multiple image is usually a result of transmission problem. The signal from your local station gets transmitted two ways, by tower and cable. If the tv receives them both at seperate times it will create an overlap or shadow effect. I would try a small power booster on it, if not a service man may have to adjust the internal circuits.
Mar 07, 2008 | Zenith B32A24Z 32" TV
Zenith 50 In Rear Projection Hour Glass
My picture is a double image and has a sideways hourglass on the screen. Please help me!
Oct 08, 2007 | Zenith IQB50M90W 50" Rear Projection...
50" rear projection zenith television
does it look like this:
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Jul 31, 2007 | Zenith IQC50H95W 50" Rear Projection...
Creative Labs ZEN Vision:M Digital Media Player Logo
57 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
