Question about Breville ESP8XL Espresso Machine
Breville cafe roma
Finding that my shots are coming out too fast! Have adjusted tamp, grind you name it. This only started after I purchased my first Conical Grinder(Breville bsg450). Used to use simple blade grinder and had much better(slower extraction) HELP
Obviously the problem is with your grind, not the Breville. SImply adjust your grind to finer.
Posted on Jan 07, 2009
I wish to purchase instruction book for Breville Cafe Roma Expresso/Cappuccino machine issue 2/02
Hello dhu... Will you settle for a free instruction manual? : ^ )
Go to this link
download the manual and the quick start guide . Joe
Thanks for choosing Fixya!
Mar 06, 2011 | Microwave Ovens
I have a Breville Cafe Roma Machine. I made about...
have you tried to use the sharp pin and try to dislodge coffee grind from the filter cup? You will need to remove it from the filter holder to gain access.
May 20, 2010 | Breville ESP8XL Espresso Machine
Coffee tastes waterdown
for grounds you need to tamp the ground hard,. Fill the port a filter to the top then tamp it until the little line is showing. Also what may be a problem is the grind is too fine, or too course
Feb 12, 2010 | Coffee Makers & Espresso Machines
Espressione cafe roma problems with pump
The problem might be the tamping pressure or the grind?
Jun 28, 2009 | Espressione Cafe Roma Deluxe 1329
Shots too watery
1, Check the grind on the grinder. Imagine grounds as rocks and sand, if you are using rocks then the water will run too fast and with sand it will run too slow.
2, If using an automatic machine(water volumes are pre-measured), check to make sure that you are getting the correct volume(3ozs fro a 2ozs shot, and 4ozs for a 3ozs shot), an once of water stays in the coffee during extraction.
3, Adjust the tamp(packing pressure) of the coffee, fill the portafilter with coffee a little over the top, then level it out and tamp to the fill ring on the inside of the basket.
Jun 03, 2009 | Wega Mininova EPU Espresso Machine
Breville Cafe Roma ESP8XL - cup is moving during the process
GET A NEW MACHINE. i just bought one used for $25. the previous owner said it had been sitting in his basement for over a year, and that he used it only maybe ten times (WHY, I WONDER?). it was not cleaned before being stored. let me preface my comments by stating that i have used a saeco-made starbucks barista machine for about 9 months now, and this one was supposed to be a backup. here are the things that i have issue with about this machine: 1) re: the thumping sound during steaming: the pump inside the machine is poorly mounted; it has a metal bar around it which, i believe (from examining the guts of the machine) has scarred an adjacent plastic piece from repeated impact, while causing the thumping sound everyone hears. one can feel the vibration on the outside of the machine by placing a finger or hand anywhere on it's surface. the cause: poor quality pump and poor manufacturing.
2) and in support of "poor manufacturing" theory: if you hold up the metal coffee filter basket to the light, you can easily see the hole. yes, coffee comes thru ONLY ONE HOLE in the filter basket. there are a score of other "holes" that you CANNOT see light thru-these are FALSE HOLES. comparing to an espresso maker that costs twice as much, every hole seen in the filter basket is in actuality a hole (light can be seen through each). clearly, the breville basket lacks a crucial/vital step in its finishing: the last step of drilling out each individual hole (instead of drilling only one).
to review: i spent $25 on this POS. how much did you spend? no wonder cust. service doesn't help!
Dec 15, 2008 | Breville ESP8XL Espresso Machine
Breville ESP8XL Espresso Machine Logo
373 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
