Is pro tools 8 going to work on my dell vostro 1500? I have XP and SP 2. I was planning to daisy chain my hard drive with my MBox 2 Pro (Audio Interface). laptop > HD > Interface (all Firewire). Any problems I might run into? thanks
I checked compatibility and the specs and i think i might be able sqqueeze by with this laptop, i can't afford to go any other direction.
-darin
Windows XP Home edition 2002
Intel Core 2 Duo
T5270 @ 1.4GHz
795 MHz, 1.99 GB of Ram
My Hp Pavilion dv5000 crashed! I bought a another Windows XP cd to install it but it won't work? I...
(More)
My Hp Pavilion dv5000 crashed! I bought a another Windows XP cd to install it but it won't work? I get an error message!!! It displays the following message!! ----------------------------------------------------------------- A problem has been detected and windows has been shut down to prevent damage to your computer. ------------------------------------------------------------------ If this is the first time you've seen this stop error screen, restart your computer. If this screen appears again follow these steps: ------------------------------------------------------------------------------- Check to see if you have adequate disk space. If a driver is identified in the stop message disable the driver or check with manufacturer for driver updates. Try changing video adapters. ------------------------------------------------------------------------------- Check with your hardware vendor for any BIOS updates. Disable BIOS memory options such as caching or shadowing. If you need to use Safe mode to remove or disable components, restart your computer, press F8 to select Advanced start up options, and then select safe mode. ------------------------------------------------- Technical Information: ***Stop: 0x0000007E (0xc000001D, 0x8089E984, 0xF7CA2CC, 0xF7CAEFC8)
CD Rom Drive E: Can no longer be found along with Drive C and D in the computer though still...
(More)
CD Rom Drive E: Can no longer be found along with Drive C and D in the computer though still installed
what can i do if my lap top won't start windows, it just turn the screen black and saids that the...
(More)
what can i do if my lap top won't start windows, it just turn the screen black and saids that the initialization fails, it's a gateway MX6920
