Question about Sony Playstation 3 (PS3) Console
Ps3 wont turn on using controller and power button...
A blackout occured while i was playing..after the power came back i turned on the ps3.it indicates on stand by mode(solid red light).i pressed the power button; it wont turn on and it doesnt work or even beeps. i also tried using the ps button on the contoller.same thing.Ps3 wont turn on using controller and power button.. its a 160gb model
    Sergeant:
  • 154 Answers
Try cycling the power on the back of the console
are the lights blinking on your controller when you press them?
Posted on Jul 11, 2009
I have a similar problem, a guest was playing at the time so I don't know what happened before it broke but I found that you can turn it on with the eject button and off with the controller.
I still don't know how to fix it though. :(
Posted on Sep 07, 2009
SOURCE:
Wen i want to play a game on line that i have is ascking to do the update, the update starts then stops freezing what should i do
Put your PS3 in Standby Mode. The first thing your going to want to know is your model number. It can be found on the back panel of the PS3 on the serial number label, and it will begin with CECH. Example - Serial: XXXXXXXXXXXX-CECHXXX -
For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back
Time to enter Safe Mode. Press and hold your finger over the power button on the front until you hear three beeps and the indicator light goes back to red. Then release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds the third and final beep will sound then the indicator light will return to red.)
Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
You will then see this screen. -REMINDER: -BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
Select option number 5. (Restore PS3 System). Then select yes to perform step. You will then see this screen. "The hard disk's file system is corrupt and will be restored.
The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
Regards.
Jan 11, 2012 | Sony Playstation 3 (PS3) Console
Tip
Fix the 80010514 error on your PS3
If your Play Station 3 (PS3) gets the 80010514 error somewhere, you can try this to resolve the problem:
1. Make sure that the power indicator on the Play Station 3 system is solid red. To do this, press and hold the power button until the PS3 beeps and the light blinks. Once the light has turned solid red, turn the power switch in the back off.
2. Turn the switch back on, then press and hold the power button.
3. Keep holding the power button even after you hear a short beep after 5 seconds.
4. After 10 seconds, you will hear another short beep and the system will shut down (release the button at this point).
5. Press and hold the power button again.
6. Continue holding the power button even after you hear a short beep after 5 seconds.
7. Release the button when two short beeps are emitted after 7 seconds.
8. As instructed by the on-screen message, plug in the controller and press the PS button
9. Select restore Play Station 3 system.
This should not affect any of your save games, demos, etc. but just to be safe you might want to back up to an external USB hard drive.
To backup saves, go to the Play Station 3 Save Data Utility, select the save you wish to copy and hit the Triangle button. Copy should come up as one of the options. If it does not then the save game is copyright protected and can’t be copied. If you can copy it, make sure you have a USB drive attached and copy it to that.
on Feb 02, 2010 | Video Game Consoles & Games
Ps3 turns on but wont do anything after the ps3 sign comes on. the controllers just blink but i cant use them and the ps3 wont turn off unless you hold the power button for 10 seconds. all i did was just...
This is a problem occurring in all the play station 3 consoles....... this is mainly because of some error in board .....as a result it leads to the damage of ur PS3 ....................try to update your system ..........
if its working good then better download this Repair Guide for further information .........
CLICK HERE to download
Aug 15, 2010 | Sony Playstation 3 (PS3) Console
How to fix a corupted hard disk for a sony ps3 ?
  • Put your PS3 in Standby Mode.
  • For models: CECHA01, BO1, E01, E01MG, G01, H01, H01MG, K01, LO1, AND P01, it will have a power switch on the back. Flip it off then back on and you will have a solid red indicator light on the front.
For models: CECH-2001A and 2001B, press the power button on the front until the indicator light turns red. If all else fails unplug the power cord and plug it back in.
  • Time to enter Safe Mode.
  • Press and hold your finger over the power button again until you hear a quick double beep. The release the button. (The second you touch it you will hear a beep, that's the first beep. Five seconds later a second beep, another five seconds you will hear the double beep.)
  • Connect the USB cable to the USB port on the front of your PS3 and the top of your game controller, (between the left and right bumpers). Then Press the PS button in the center of the controller.
  • REMINDER: - BY DOING THE FOLLOWING ALL OF YOUR DATA ON YOUR PS3 WILL BE LOST, YOUR ONLINE STATS ARE ON THE NETWORK SO YOU WILL GET THAT STUFF BACK, INCLUDING GAMES AND ADDONS YOU BOUGHT FROM THE PSN.-
  • You will then see this screen. "The hard disk's file system is corrupt and will be restored."
  • The PS3 will then restart. You will see many different languages, all that is is saying is, "Connect the controller with the USB cable, then press the PS button". Press the PS button and set your settings when it finishes it will start up and its fixed!
Good Luck and have a nice day.
Thanks for using Fixya
Jun 09, 2010 | Sony Playstation 3 (PS3) Console
Ps3 on screen is saying hard disk is corrupted
I wish you good luck.
Mar 25, 2010 | Sony Playstation 3 (PS3) Console
PS3 turned off because of a blackout, it is plugged to a battery backup aalong with the TV. The TV went off and came back on no problem but the PS3 won't turn on using the power button on the console or...
Sometimes when the Power goes off, the unit is left plugged in, & left ON, now, when the Power is restored, it may spike, or surge damage the unit, unfortunately. The "Inrush" current can be very high and this is what destroys the power Supply. generally. I suspect this is what has happened. I get clients that have this happen all the time, often they get me to write a report for their Insurance Company so they can make a claim, as this type of thing, at least in NZ is covered by that.
Mar 04, 2010 | Sony Playstation 3 (PS3) Console
Hi my hard disk's file system is corruped how can i fix it?
Connect controller to PS3 screen.You will then see a screen. "Connect the controller with the USB cable, then press the PS button".
Safe Mode options screen. Connect controller to PS3 screen.You will then see this screen. Safe Mode options screen
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
Corrupt hard disk
Connect controller to PS3 screen. You will then see a screen. "Connect the controller with the USB cable, then press the PS button".
Safe Mode options screen. Connect controller to PS3 screen. You will then see this screen. Safe Mode options screen
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
My PS3 hard drive is saying ''corrupt''. I have only use this system 15 or 20 times total. Is there something I can try before having to buy a new hard drive? When I turn it on, it goes to a screen that...
Connect controller to PS3 screen. You will then see this screen. "Connect the controller with the USB cable, then press the PS button".
Safe Mode options screen. You will then see this screen.
You will then see a screen. "The hard disk's file system is corrupt and will be restored."
Feb 14, 2010 | Sony PS3 40GB Best Sellers Bundle Console
Sony Playstation 3 (PS3) Console Logo
1,093 people viewed this question
Top Sony Video Game Consoles & Games Experts
shevantha perera
Damen Wong
Damen Wong
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
