Hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
To
troubleshoot the issue, click the link below:
Car Repair Diagram
http://technoanswers.blogspot.com/2013/03/car-repair-diagram.html
HOT/WARM START ISSUE
Its
a hot start issue.
Can
be related to low fuel pressure or problem with crank sensor.
Also
it can be weak battery or starter.
But
possibilities are to be inspected to confirm what exactly it is.------
To
troubleshoot and confirm the issue,i suggest you refer few solved help links
with similar types of problem like yours:------
Click
the link below:------
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These
details will help.
Thanks.
CAR NO START PROBLEMS:-----
It
can be the issue with weak battery or faulty battery or if battery is ok,then
its faulty starter causing the issue.
From
start to end troubleshooting these problem i suggest you to click the link
below and follow its procedure:-----
What to Do When Car Turns Over But
Won't Start?
http://technoanswers.blogspot.com/2012/11/what-to-do-when-car-turns-over-but-wont.html
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
http://whoisbyme.blogspot.in/2012/06/car-starting-problems.html
http://whatisbyme.blogspot.in/2012/06/1999-chrysler-cirrus-8-ign-fuel-starter.html
http://whatisbyme.blogspot.in/2012/05/2001-toyota-camry-no-start-after.html
http://www.howtorepairguide.com
These will help.
Thanks.
It
From
Won't Start?
These will help.
Thanks.
It
From
Won't Start?
These will help.
Thanks.
It
From
Won't Start?
Car starting issues?
Car Starting Problems
1991 Toyota Trecel: Engine Starts fine but
dies when gets Warm?
1994 Toyota Pickup: Starts fine but dies in
few seconds?
1999 Chrysler Cirrus: 8 IGN Fuel Starter Fuse
Blows?
2001 Toyota Camry: No start After replacing Battery?
1989 Toyota Pickup Truck: Turns over but not
start?
http://whatisbyme.blogspot.in/2012/05/1989-toyota-pickup-truck-turns-over-but.html
Car dead and will not Start?
http://whatisbyme.blogspot.in/2012/05/car-dead-and-will-not-start.html
1995 Lexus LS400: Running Hot?
2001 Toyota Prius will not start?
http://whatisbyme.blogspot.in/2012/05/2001-toyota-prius-will-not-start.html
1996 Jeep Grand Cherokee: Engine will not start?
http://repairhelpcenter.blogspot.in/2012/06/1996-jeep-grand-cherokee-engine-will.html
Mitsubishi will not start
These will help.
Thanks.
