Question about Toshiba 32A33 32" TV
Unable to change v-chip code in my sharp television set HELP
I entered the wrong secret code, when asked what the secret input number was on my parental control now i can only watch g rated movies
Re: unable to change v-chip code in my sharp television...
Go to Sharp webste download your manual for the tv and whala it is done...
Posted on Jan 07, 2009
    Problem Solver:
  • 8 Answers
Activate the service menu of sharp tv. press @ hold the channel up then swicth the power.
Posted on Jul 05, 2013
0 characters
3 Points
Please give me .....TV SHARP Password???
.sharp X Flat Slim TV model number 21G-FX35 i lost my password please tell me its master password
Nov 27, 2010 | Sharp 27C-240 27" TV
How do I remove a Vchip from a Sharp TV no code?
Default code is "0000" on most sharps to enter the V-chip settings. If not you will have to reset the password which is listed in the manual if you have it.
Clearing the password or secert number on newer sharps are as follows.
1. Press MENU to display the MENU screen, and then arrow to "SETUP"
2 . Then select on of the options until the password or secert number input screen dislpays.
3. Press and hold both the "Channel Up" and the "Volume Up" buttons simultaneously until message apperas on the screen. Then you can enter new or leave blank number.
If this doesn't work goto sharps web site and download the manual if available.
Mar 15, 2010 | Sharp 32C-240 32" TV
V-chip activated
Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN (9) on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be.
Mar 14, 2010 | Sharp 32C-240 32" TV
It may be a parental lock, so u need the code or u have to reset it, check the manual on how to reset it
Dec 16, 2008 | Sharp 25R-S100 25" TV
Can't get the child lock off
You can use theV-Chip Parent Lock to
Block or Allow programs based on the
ratings sent by the broadcast stations.
The default setting is to allow all programs.
You can block programs by the
type of program and by the categories
you want blocked. Or you can block all
programs during a specific time period.
To use the V-Chip Parent lock, you will:
• Enter a passcode
• Select theV-chip ratings and categories to block
• Select theV-chip hours to lock and unlock for television programs
• Select lock by time
Enter a Passcode
I. Press _ to display the Main Menu.
2. PressAorV to select V-Chip Parent Lock.
PressE_ R,
3. Using the number keys, enter four numbers. To
delete a character and move back one space, press
. Press _ to set the passcode and go to
theV-chip ratings menu.
4. To exit without entering a passcode, press _ to
go to the previous menu or _ to return to
television viewing.
If you forget your four-digit passcode, please
see Appendix 3 : Procedure for Bypassing the
After you set the lock, you will need the secret code in order to:
• view a locked program,
• view the locked TV, or
• cancel the lock.
If you forget the code, you can view the locked TV without entering the code. To do this, simply
press the buttons on your remote labeled "QV" and "9" at the same time whenever your secret
code is requested. Unlocking theTV this way is temporary.
To change or permanently cancel the lock:
I. Turn on your TV. If the TV requests your secret code, press
and_ at the same time.
2. Press _ to view the main menu.
3. Use the • o rV to select ..V..-Ch p Parent Lock and press ENTER .
4. The on-screen display will ask for your current passcode. Press
and _ at the same time.
5. The on-screen display will now ask you to enter a new code:
• To cancel the passcode permanently, press _ or _ .
• To change to a new passcode, use the number buttons to enter a
new code, then press E_R,
You must use the remote control included with this
TV. You cannot use a remote control from another
Mitsubishi component and you cannot use "Univer_
sar' remotes from other manufacturers.
Nov 24, 2008 | Mitsubishi VS-55707 TV
I dont have vchip code fof my used tv
1. Hit the Menu button on the TV. 2. 'INPUT SECRET No.' should appear. 3. Press and hold both VOL (+) and CH DOWN on the TV set simultaneously until the message 'INPUT SECRET No.' disappears. 4. The vchip settings should be disabled now and the Parental controls menu should be presented, 'disable' Status if need be
Remember do it on the tv not the remote
Nov 14, 2008 | Standard (CRT) Televisions
Parental Control V chip has been activated.
on my Sharp 36R-s400. Go to menu , then parental control. When dispaly asks for secret number,
press and hold volume up and channel down simultaneously until message is cleared.
This turns off parental control and clears the password.
Sep 06, 2008 | Sharp 19R-M100 19" TV
Resetting my parental passcode
Hi haventaclue
I searched for your manual but came up empty handed(for free at least). There are places you can pay to download it, but I did find this one, and similar vintage to yours, that has instructions on the parental control. Not sure how to reset the code. I did find this on page 18, it regards setting up a secondary set of blocks. Perhaps you could try that.
• If you intend to change or forget your Secret No., clear the original Secret No. and set
up a new one.
1 Repeat steps 1 to 3 of [1] MPAA RATING, or 1 to 2 of [To cancel
the V-CHIP BLOCK screen while V-CHIP BLOCK has been
activated], then “INPUT SECRET No.” will be displayed.
2 Press and hold both VOL (+) and CH DOWN (9) on the TV set
simultaneously until the message “INPUT SECRET No.”
3 Press MENU two times to exit.
I am more than happy to answer any other questions you may have about it, please get back to me here, or use the ASK function to go straight to me :) If you are still unsure, have problems, or we need to look at the situation more deeply, then before you give a rating for this advice, hit the ASK button Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
Jul 08, 2008 | Standard (CRT) Televisions
Resetting V-Chip pin code
I don't know the sharp(mfg) code to activate my universal remote
May 12, 2008 | Sharp 27U-S60 27" TV
Forgot v-chip code
Sharp has several locking and V-chip commands but one of these three possibilities should work.
Newer Combos With "Time Limiter" Feature
If the "Secret Number" is forgotten, simultaneously press the STOP, RESET, and VOL up buttons on the front panel of the set.
This disables both the "Channel Lock" and the "Time Limiter" features.
CTV's Lock Mode---Blue screen and display says,Parental Control Rating Unknown
Try This: Hold Channel up and down on the set while pluging in AC cord.
Or Try This: On the set, press volume up and channel down at the same time.
CTV's V-Chip Release
When screen asks you to "input secret number" press and hold channel up and down on the TV set until message disappears. Press menu 2 times to exit.
Hope this helps!
Nov 13, 2007 | Sharp 25R-S100 25" TV
Toshiba 32A33 32" TV Logo
1,070 people viewed this question
Top Toshiba Standard (CRT) Televisions Experts
Jaime Hernandez
Are you a Toshiba Standard (CRT) Television Expert? Answer questions, earn points and help others
