Question about Acer AL1916B 19" LCD Monitor
Monitor won't turn on
My Acer AL1916 has been working fine for 6 or 7 months...went to turn it on one day and the monitor would not turn on...i tried new cables and a new video card, but had not success...please help!
  • 1 more comment
  • soulmusic Dec 08, 2007
    Monitor will not turn on,working fine one day then the next will not switch on tried new leads etc
  • Anonymous Jan 02, 2009
    I have opened up my AL1916 monitor to check the capacitors as was previously suggested. I don't see any of them that look abnormal. Is there anything else I can check? I don't have any special equipment here, but I do have a meter, if that is any help.
  • rthayer286 Jan 02, 2009
    I opened up my AL1916 to check the capictors as suggested. I don't see any that look abnormal. What else can I check?
  • 180 Answers
Capacitor has shorted in the main board. Try to look for any buldging capacitor and change it. It will be ok then.
Posted on Apr 20, 2008
How to change monitor aspect ratio for acer AL1916
The aspect ratio is expressed as two numbers separated by a colon (x:y). and they actually represent the relation between width and height of (in your case) your monitor.
Did you mean to change the resolution of your monitor? Could you please explain your problem in more detail? What is it exactly you want to achieve?
Oct 22, 2013 | Acer AL1916 A (Black, Silver) 19 inch LCD...
Acer AL1916 monitor wont turn on
normally along the number keys are cymbals, you must look for one that is a wireless sign, then i think you must press a key with this key to enable it, normally its a fn key
Nov 29, 2009 | Acer AL1916W 19" LCD Monitor
Acer al1916 monitor, yellow picture
If your menu button is not working then you cant to do anything. I adviced to you pls check it from service center.
Oct 15, 2009 | Acer AL1916W 19" LCD Monitor
My ACER AL1916 blinks several times before picture is displayed when the monitor is turned-on for the first time in the early morning and stays stable all day. I connected it using VGA cable. Any...
Usually this happens when the monitor is trying to translate the signal given off by the video card.
Nothing to worry about, simply a process that the system needs to go through.
If this solution has helped you, please take the time to rate me.
Oct 04, 2009 | Acer AL1916W 19" LCD Monitor
Acer AL1916 LCD monitor is getting darker!!
sounds like backlight is failing,contact acer and see if its under warranty.
Mar 04, 2009 | Acer AL1916B 19" LCD Monitor
Acer moniter model AL1916
Check the cables and the computer connection VGA outlet.
If doesn't work and your monitor is under warranty ACER will repair your monitor for free.
If not, the better option is get a new one instead of repair due the high cost.
Oct 14, 2008 | Acer AL1917W LCD Monitor
Green Flash power only on one computer
It sounds like the monitor functions properly and your computer functions properly, but the combination causes a problem. Try making sure the screen resolution on your main computer is set to an acceptable resolution for your monitor - AL1916. Try setting it low to 800x600 and move up from there until it doesn't work anymore. You can change the screen resolution from the Display Settings (right click on the desktop and select Display Settings) window.
Jun 11, 2008 | Acer AL1916B 19" LCD Monitor
Acer Monitor
You're going to have to provide more info than that.
What were you doing when it happened? What are you typically doing when it happens? Have you checked your cables? Power connection?
As it stands, your inquiry will not receive much of a useful solution for you unless you let us know these things.
And don't rate me poorly for letting you know this. I'm here to help you. You have to HELP US help you.
Dec 10, 2007 | Acer AL1916B 19" LCD Monitor
This may not be a Monitor problem. So if you can try to get to test monitor on another computer. Check carefully the data cable to ensure there are no bent pins. If it turnout to be a monitor problem then at only 6 months -Acer should replace it. If the monitor works - you should have the graphics card on the computer checked out. If you feel you can do this - and you can- basic checks come back as another request.
Jun 06, 2007 | Acer AL1916B 19" LCD Monitor
Acer AL1916B 19" LCD Monitor Logo
708 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
