An 1 1/2" of the display flickers and goes black. It is not the video card as I have hooked monitor to another PC and the same problem exists. When the monitor is 1st turned on it works well but the color is different on the last 1 1/2" of screen. After warm-up it (the ! 1/2") flickers then goes black.
Comments:
Nov 14, 2007
- I should mention it is a LCD display monitor. A ViewSonic n1700w. It is the right side 1 1/2" giving me the problem.
X2Gen MW22U monitor starting flickering upon startup a few weeks ago. The flicker would only last...
(More)
X2Gen MW22U monitor starting flickering upon startup a few weeks ago. The flicker would only last for awhile and then it was normal. Then a few days ago the monitor went out completely. Every time I power it up, it either blinks a little, or just gives a static/electrical noise, and then stays blank. I've only gotten it to come on a couple of times and it only lasts for a few minutes.
I saw some posts here about bad capacitors, so I took it apart to see if that was the issue. The capacitors don't appear to have any damage, but I did notice something. There's a set of four wires that connect the two circuit boards (red, orange, white, black) and the red wire is burnt at both ends ... enough that the insulation turned black and the white connector turned brown at that wire.
Any ideas on if this monitor is fixable ... and how?
lg2234s monitor goes of blinking...cant turn monitor off (blue light remains off) then monitor turns...
(More)
lg2234s monitor goes of blinking...cant turn monitor off (blue light remains off) then monitor turns on ..screen pic returns but is totally green, the OSD becomes garbled, if set to return to default then everything becomes normal, using osd buttons also blanks out screen and blinking of screen occurs again..osd is all garbled even if pc is switched off.
