Question about Cooktops
Viking ceramic cooktop numbers washed off
How to replace numbers that were "silk screened" onto stainless steel frame - and washed off. These are the numbers surrounding, but physically separate from the control knobs. They indicate the heating levels for each control knob which is used to control one or both of two concentric elements per knob. Viking's only solution is to buy a new cooktop. How ridiculous. Have you seen this problem before and/or do you have a reasonable solution for it?
Thank you,
Dan Ellis
I have the same problem. The previous suggestions are assanine and have Cleary not actually read the question. The question is how to replace the original heat numbers that rubbed off.
Posted on May 19, 2012
  • 619 Answers
SOURCE: Frigidaire Ceramic Cooktop PLEC36S9eca - Turns on but burners won't heat up
Check the power plug is their any separate plug on it / if none check the control panel some switch to power on .
Posted on Jan 05, 2008
  • 111 Answers
SOURCE: whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Posted on Dec 19, 2008
Kgt1962
  • 59 Answers
SOURCE: Only 1 of 5 burners is working on my Viking electric cooktop
By only 1 burner working, I take you mean only 1 ignites, then it sounds as though you have an issue with the spark module being defective. There is usually an access panel on the bottom of the unit, although not on all of them. Remember to disconnect from the electric.
Posted on Mar 05, 2009
DeBruce
  • 145 Answers
SOURCE: How to remove brown scorch mark on stainless steel cooktop cover
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Posted on Apr 29, 2010
  • 949 Answers
SOURCE: My ceramic cooktop has cracked. Can I just order
You can get the main glass top, the part number is WB62T10525 and it runs just under $300.00, it is shown here as 51. It does take a bit of dis assembly to install it.
Posted on May 05, 2010
The glass of the electric cook top is lifting from the stainless steel frame
[PDF]Professional Performance for the Homeā„¢ - Viking
www.vikingrange.com/.../m10103_viking_built-in_surface..
Viking RangeFortunately, our built-in rangetops, cooktops, and gas woks offer the ... sealed or open burners, every Viking gas rangetop delivers unrivaled ..... The only thing cleaner than the glass ceramic surface of Viking electric cooktops is the installation.
Sep 30, 2015 | Viking Cooktops
I need to replace the numbers around the control dials, they are black on stainless steel and keep peeling off.
Sadly, your etching came off the top. Only fix would be a new laser etched top. But it's expensive. Call 888-845-4641 for parts distribution depending on your location. East is Atlanta, West is LA.
Jan 29, 2015 | Viking Designer Series DECU1655BSB
Viking cooktop DECU165-5B stainless seperated from
It can cause a fire. The same thing happened to me fortunately I ha dthe extended warrantee and it was covered. This is a common problem and should be addressed by Viking. After all it is not a cheap appliance.
Jul 21, 2010 | Viking 31 in. DECU165 Electric Cooktop
Mar 26, 2010 | Jenn-Air JGC8536 Gas Cooktop
Three small burners work three large dont
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Mar 24, 2010 | Viking Professional VICU165 Stainless...
My Jenn air range top is becoming stained.
We Use Debruce Polish on all our cooktops. Debruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Mar 26, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Cleaning Thermador Cooktop?
To clean the stainless around the star burners try applying Easy-Off oven cleaner around the stars with a Q-tip (spray the cleaner onto the stainless surface first because it's very hard to control the spray output). The cleaner will make your stainless sparkle and the Q-tips allow you to get close enough while controlling the application. Scrub gently with the Q-tip and the stains will disappear within minutes. Wash thoroughly with a wet cloth. I've used this on my older model Thermador stainless cooktop for 5 years.
Mar 20, 2008 | Thermador PSC364GDZS Gas Cooktop
Jan 02, 2008 | Frigidaire PLEC30S9EC Stainless Steel...
Ceramic cook top popping up
from the counter top or the metal cabinet its in
Nov 28, 2007 | Viking 31 in. DECU165 Electric Cooktop
Cooktops Logo
161 people viewed this question
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
