It's possible you have a lot of dust build up inside the stat. If it has batteries remove face from wall and blow out. Take outside to see if temp will change. Plug the hole in the wall where the wire comes through. If all fails, replace. Turn power off, take wiring picture, replace, turn power on. Good Luck!!
Try to leave it on with no battery supply until it runs completely out of charge and switches off. Only then connect it to your PC and see if it communicates with the software on the PC. If it's still frozen you need to restore it to factory settings.
Let's get started: 1) By code, the microwave? should be on dedicated circuit 2) You have 4 cables that enter the box. 3) Only 1 cable will be Hot and Neutral from breaker box. You must identify this cable first. Here is drawing: http://waterheatertimer.org/images/Pantry-door-switch-1000.jpg
Check coolant level. if ok then see if engine comes up to temp. 190+ at thrmostat housing. If not, replace thermostat. If thermostat is ok, feeel heater hoses. If one is hot , and the other cold, then remove both and flush heater core. If both are hot, suspect blend door problem in heater box. probably need pro help for that.
The Toshiba Satellite pro 6000 doesn't have a built in microphone as far as I can remember but it does have a microphone socket at the front next to the headphone socket. Both sockets are on the bottom left hand side left if looking from the front. The microphone one is the one on the left, if you look closely there are symbols next to each of the sockets, one looks like headphones the other like a microphone.
