Question about Curtis DVD8017 Portable DVD Player
Movie does not play
When i put the dvd in it spins but the blue screen that says curtis stays on and the movie does not play
  • 2 more comments
  • ecj98 Nov 19, 2007
    When I put a movie in, it just keeps loading and eventually says no disk.
  • Leroy Prieto May 10, 2008
    Will not play the movie it says to that there is no disc all it dose is spin and show the blue screen
    Will not play movies says no disc, stay on the blue screen when you start the movie dvd is spining
  • Anonymous May 25, 2008
    My DVD player just displays 'loading' until forever.
Alex you did a great job
Posted on Dec 08, 2007
    Problem Solver:
  • 5 Answers
Try playing Different DVDs, Second Make sure which Region Disk your playing is it Region 1 or Region 2, If your DVD player is Manufactured in USA it plays only Region 1, If its manufactured in UK it plays only Region 2, If still you face same problem Use Lens Cleaner, If still you face same problem do Reset.
To Reset Dvd player, Remove DVD from Dvd Player, Unplug Power chord from Walloulet for 15minutes so player goes to Defult Factor Settings, Then plug back again Power chord. Turn on Dvd player insert DVD, It should Play or else Claim Warranty.
Posted on Dec 05, 2007
When I try to play a Blue Ray DVD movie I get the
Use a q tip with a little bit (not dripping) of rubbing alcohol. Eject the tray,unplug, look for laser,you may have to do a little bit of disassembling,but have no fear if you have a digital camera at hand. Use the q tip and gently spin it between your fingers and lightly press against the laser lens. Let the lens dry and look for streaking,if it streaks,youre using too much alcohol. After cleaning,test with an audio cd,then regular dvd,then blu ray. If it works awesome,if it doesn't then the laser is most likely burned out.
Nov 01, 2009 | Sony Televison & Video
My ps3 doesn't play blue ray movies
This is a common problem on the PS3 unfortunately and is caused by a faulty blue-ray drive. Unit will have to go back to Sony for service.
You should try a DVD cleaning disk first to be sure that dirt on the laser lense is not causing the issue.
You can also open the case and clean the laser lense with a Q Tip and an alcohol cleaning solution.
If you plan on opening the case at any stage please ensure the unit is disconnected from its power supply.
If this fails and you are confident with electronics there are several videos on YouTube showing how to replace the drive if you choose to order it and do it yourself.
See an example below.
Hope this helps. Please remember to rate my answer. Many Thanks
Aug 30, 2009 | Sony Playstation 3 (PS3) Console
Curtis DVD-8009 picture freezes
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 11, 2017 | Curtis DVD8009 Player
Won't play movie...only loading screen
The cause of this is a dirty pickup laser, a DVDcleaning disk might be of help.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
May 24, 2009 | TruTech PVS12701 Portable DVD Player
Disney dvd player wont play movies (dvd) but plays music (cd) fine
Might be the type of movie - some of them are only able to play "G" ratings. Try this: click <play> 1234 <play> It will likely unlock the dvd that is in and will begin to play. You will have to do the 'code' each time, or there's an unlock program you can purchase.
Aug 07, 2008 | Disney Princess DVD Player
Curtis DVD8017 portable dvd player
Try cleaning the DVD lens with a cotton swab moistened with isopropyl alcohol. The DVD lens is what emits the laser from the unit. Let it dry and try again. Also try using a different DVD. Let us know if it worked and don't forget to rate me :)
Jan 07, 2008 | Curtis DVD8017 Portable DVD Player
Stops playing
If the warranty is already expired, and you have some spare time, VERY carefully, remove the screws on your player and look for dust. This could be causing overheating. Also, if it freezes, try feeling for hot spots. A blown fuse could be causing this and you may be throwing away a 2 dollar fix. If this does not help, bring it to your nearest technical assistance provider and tell them your situation.
Jan 02, 2008 | Curtis DVD8017 Portable DVD Player
Dvd will not play movies
Are you trying to play a DVD-ROM? Some sets won't play anything but conventional movies, leaving you to put the disc in a computer to watch it...accordianman
Oct 20, 2007 | Disney 13" TV
Wont play some newer rented DVD movies
If it is a blue ray, you need a blue ray dvd player.
Aug 26, 2007 | Curtis CMD5000 DVD Player
Disc does not spin/struggles to spin
If the relevant problem only occurs while watching a DVD movie, and everything is fine besides this (i.e. if the device lets you listen to an Audio CD without creating any problem) the problem might be related to the buffer. Because it simply needs larger available space of RAM to use when spinning a DVD compared to a CD. In my opinion, the problem of your DVD player is derived from a buffer underrun state. If I am right, there is nothing to do! Unfortunately, I have to say that if it was a computer , I would easily suggest that you upgrade your RAM. But, sorry..
Apr 16, 2007 | Curtis CMD5000 DVD Player
Curtis DVD8017 Portable DVD Player Logo
285 people viewed this question
Top Curtis Televison & Video Experts
Rommel Balcita
Are you a Curtis Televison and Video Expert? Answer questions, earn points and help others
