Make sure your wiring is correct. You can try switching frequencys to see if that works. Otherwise, you might need a new receiver. That's just a low-end store brand fan.
The Bose Wave Radio has two brightness levels: Bright Hi (with a range of 8-15, and default of 10) and Bright Lo (1-8, default 4). The radio automatically goes from Hi to Lo when a room is darkened so the display doesn't interfere with sleep.
On recent models you can reset the defaults to make the display brighter or dimmer in both Hi and Lo levels.
1. Press and hold the Alarm Setup (Menu) button on your remote until -setup menu- appears in the display.
2. Then press the Tune/MP3 button until Bright Hi- appears. Use the Time - or Time + buttons to change the settings.
3. Go to Bright Lo- and adjust that setting too if necessary.
4. Press Alarm Setup (Menu) again to exit setup, or simply wait 10 seconds.
You're done! Note that if you set both Hi and Lo to 8, the brightness will stay the same all day and night.
I would double check the wiring of the fan. Is the remote an add-on that was purchased separately, and did it include a receiver unit which is installed in the fan housing? If so, I would double check the wiring of the receiver unit.
Simply use regular bulbs. It sounds like it is switched electronically probably via a dimmer. If the CFL lamps are not specifically labeled dimmable they won't work. I have seen the LED lights work where the CFL lamps will not. If you want to use CFL then replace the dimmer.
If you're not looking specifically for temp to cook specific food items, rather what lo, med low, med etc mean . . . from the packing insert lo is 185 degrees, med low is 225 degrees, med is 300 degrees, med hi is 375 degrees and hi is 415 degrees. I just purchased this item yesterday.
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
I just found this on another site. The answerer there said he hit "med-hi-med-hi" on the remote. I tried that, nothing seemed to work. I was impatient and frustrated and I did that a bunch of times, then tried "lo-hi-lo-hi" a few times. Anyway, I finally gave up and it worked! So it was one of the combos of 2 speeds that worked. It's great!
go to a radio shack to find replacement knobs. get something called a "bar knob." this has a set screw which holds the knob on the thermo shaft. use a marker and print lo med high and off on the unit or use a brother p touch label maker.
