Question about Astar LTV-3201 32 in. LCD Television
Television won't turn on.
The tv won't turn on and there is no green light indicating that the power is on.
Re: television won't turn on.
I ordered a power board from Astar through an electronic dealer. Astar would not sell to me only a licensed dealer. However, the power board was blown. My set is working just fine now.
Posted on Nov 23, 2007
0 characters
3 Points
Sony bravia kdl-32bx300 wont turn on
Mar 14, 2016 | Flat Panel Televisions
My Sharp tv remote will not turn on / off tv. It will turn on by the main power switch on tv but not by remote.
From page 8 of the manual:
The POWER indicator on the AQUOS television should light GREEN indicating you have power to the AQUOS television.
If the POWER indicator on the AQUOS television still does not light up, press TV POWER on the remote control to turn the power on.
Dec 04, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Blue light comes on but tv won t turn on no picture or sound nothing works
The blue light merely indicates power is getting to your TV. The internal power supply may have failed.
Aug 15, 2014 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
Turn tv on. green light solid display, no picture or sound
The flashing green light is likely indicative of a self-test failure, indicating the TV has detected some sort of internal fault. With no picture or sound, one strong suspect is the power supply. Flat-panel TV's have an internal DC power supply that converts the inbound AC current, and when these fail, or are unable to supply a minimum level of power to the set, it can behave as you describe, providing only enough power for the green light to illuminate.
Jul 28, 2012 | LG 50PG60UD 50 in. HD-Ready Plasma TV
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
Green flashing light on receiver of pioneer elite 434pu tv won't turn on
most likely a bad power supply and boards or service info for these sets is hard to come by. Not a do it yourself fix for most people.
Apr 22, 2012 | Flat Panel Televisions
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
Sharp lc-22sv6u won,t power on. no green light.
Sound like the TV is in protection mode. This happens when a part goes bad inside. the TV turns OFF to protect the other parts from being damaged.
Most commonly it's a power supply related issue. A bad capacitor or transformer on the power supply board is to blame.
For a do-it-yourself fixer with electronic experience, a Service Manual is the best for trouble shooting the problem down to the bad part. Normally, you can find it over the internet for less than $20.
Jul 31, 2009 | Sharp Aquos LC-22SV6U 22 in. LCD EDTV
Vizio P50HDM No Picture/No Sound
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Green flashing power indicator light
similar problem with my Sony. Unplugging for 36 hours solved the problem for me
Sep 29, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Astar LTV-3201 32 in. LCD Television Logo
44 people viewed this question
Top Astar Flat Panel Televisions Experts
Jaime Hernandez
Are you an Astar Flat Panel Television Expert? Answer questions, earn points and help others
