Question about Toshiba SD-V280 DVD Player/VCR
DVD player - ERR
All of a sudden, no matter what disc is put in - The TV will show the Toshiba DVD welcome screen but there is a black box in the upper left hand area of the screen that says "Incorrect Disc"..
Even when the disc is a "store bought" - play anywhere - type of disc.
It will not even play the discs that were recorded and finalized on the unit.
Can you help??
Re: DVD player - ERR - Toshiba SD-V280 DVD Player/VCR DVD & Blu-Ray Players
Error in any disk i put in!!!!!!!!!
Posted on Nov 23, 2008
  • 3 Answers
I PRESS SETUP on REMOTE then go to TV ASPECT move it to 16:9 PUT CODE 1,3,9,7,1,3,9 then press ENTER and it will reset to factory mode and it will say DONE . PRESS ENTER to load DVD .... THAT'S WHAT I DID AND IT WORKED FOR ME >>> I DON'T CARE FOR TOSHIBA MUCH I'VE HAD TO MEANY PROBLEMS WITH THERE PRODUCTS >!!!!!
Posted on Sep 11, 2013
0 characters
3 Points
How to use the dvd player how to play a dvd how to get a picture
should be with the remote---whatever input on the rear the unit is connected to you have to switch the set to THAT input to see the DVD
Oct 31, 2012 | DVD & Blu-Ray Players
Screen on TV shows Toshiba label and says there is no disc but a disc loaded in it
The laser unit has gone bad. Usually it's not worth replacing as it is about 3/4 the cost of a new player.
Jul 25, 2009 | Toshiba SD-3990 DVD Player
Black box appears on screen
I have a black box that blocks my picture, Sharp flat screen
Jul 17, 2008 | Toshiba MW24F52 24 Inch TV with DVD / VCR...
Toshiba HD A2Ku
It will take almost a minuted for the player to boot up and appear on screen, providing I am assuming you have your TV set to DVD setting.
Your DVD then when booted up will say "No Disc" if you dont have a DVD in it, course with one in it, your movie should appear.
Jan 16, 2008 | DVD & Blu-Ray Players
DVD appears to not be reading or recognizing discs
Unfortunately your DVD drive mechanism looks to have bit the big one.
You can try taking it apart, removing the top of the drive and cleaning the lense. Work it up and down. Use a q-tip with a little squirt of windex on it.
Reassemble and try it again. If you get the same results, it's time for a new DVD player.
Dec 27, 2007 | Toshiba SD-V392 DVD Player/VCR
DVD player issues
Most likely the dvd is dirty, scratched, or chipped. Try cleaning the dvd disk with a soft cloth (chamois works best). Look at the surface of the disk and if it is scratched lightly, dust and dirt particles, fingerprints, etc will cause refractions from the laser light in the dvd player, which is then read as an error by the dvd player. Cleaning it with a soft cloth will sometimes help.
If that does not work, hold the disk up towards a light source and look for light coming through from the other side. If this happens, the disk is unreadable and unrepairable as the data source has been corrupted.
Dec 17, 2007 | DVD & Blu-Ray Players
Dvd player doesn't recognize dvd's of any kind
jusguessin should call Toshiba quickly. The units have a 1 year warranty. Do not open the unit or it will void your warranty (I know, I do Toshiba warranty repairs on their recorders. If anything will make be void a warranty, it's a consumer who opens the unit and pokes around inside).
mooch, clean the laser head. I wish I could refer you to a FAQ because this is about the 10th time today I have written this.
Open the unit. Remove the DVD drive. Take the top off of the DVD drive. Clean the lense with a q-tip with a little windex on it. Work the head up and down gently. Reassemble and test. If problem presists, go buy a new one.
Sep 16, 2007 | Toshiba SD-V392 DVD Player/VCR
Portable dvd
err disc, what does it mean? My player suddenly displayed this error message, how do i solve it?
Aug 18, 2007 | NextBase SDV-17 Portable DVD Player
DVD player does not read discs anymore
the Laser is most likely defective. most likly it will need replacement. There is no correction that can made to correct the problem except to that of a replacement of the laser
Apr 06, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Toshiba SD-V280 DVD Player/VCR Logo
453 people viewed this question
Top Toshiba DVD & Blu-Ray Players Experts
Are you a Toshiba DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
