Question about Acer Aspire™ T180 PC Desktop
High Pitched Squeal
I bought an acer aspire T180 anout 2 months ago and it has been running fine up until now.
it has recently developed a high pitched squeal which i cannot find a source for. it is not coming from the speakers, and i have disabled all hardware that i'm not using such as the modem, and i have also cleaned out all the dust from the inside. can anyone help?
Re: High Pitched Squeal
None of these help me at all,this is plaguing my laptop to the point where it is not operational
Posted on Oct 20, 2008
  • 1,601 Answers
It would have to be somthing that is moving, like harddrive or fan.
can you look inside while it is running?
Posted on Nov 14, 2007
0 characters
3 Points
High pitched squeel from the hard drive and then shuts down.
restart the computer HOLD the keys CTRL +F11 OR F12 depend of your mark, model, and go restore to the factory default, and fix it.
Passs the antivirus+antimalware very IMPORTANT!
God bless you
Jul 20, 2013 | Acer PC Desktops
High pitch screeching on my pc cannot fix thru speakers check ok
Unusual noises coming from your computer can mean anything from serious trouble to no problems at all. The uncertainty, together with the expense of computer hardware components -- not to mention the risk of losing data and being without your computer -- make it important for you to investigate any unusual sounds as soon as they come to your attention.
Normal Sounds
Not every high-pitched sound coming from your computer suggests a problem. Computers also generate a variety of sounds as part of their normal operation. In particular, anything that spins can easily make noise. This includes cooling fans and the hard drive. In the case of fans, their sound sometimes grows louder when the computer works harder because it needs to run the fans at a faster speed in order to dissipate the extra heat from the higher level of operation. You probably don't need to concern yourself with an unknown high-pitched sound unless you have used the computer for a while and the sound is new. b> Capacitors Capacitors sometimes make a high-pitched buzzing sound, either when under a high load or when defective. In the latter case, faulty construction can cause gas to build up inside the capacitor, which then vents under pressure and sometimes creates an audible noise. Defective capacitors can damage or destroy other hardware. f you suspect a bad capacitor, or don't know what else it might be, give your computer an inspection. b> Capacitors Inspection b> Your computer has capacitors all over it, including on the motherboard and on nearly everything that plugs into the motherboard, so tracking down a bad capacitor can take some time -- especially if you don't know whether a capacitor is actually causing the problem. Many capacitors look like tiny little soda cans and smaller ones look like squat cylinders. Failed capacitors usually bulge out at the top or have crusty residue around them. Be sure to check not just the motherboard but also any other hardware components with visible capacitors on them. If you find a bad capacitor, keep looking in case you find more. Afterward, don't use your computer again until you repair or replace the faulty hardware. Fans b> The bearings and motors on fans sometimes go bad. If this happens then the fan may begin to whine, whether or not it stops working. If feasible, open the side panel of your computer tower with the system running and try to pinpoint the exact source of the sound. If you can determine that the noise is coming from a fan, power down the computer and replace that fan. b> Power Supply Unit b> Power supply units sometimes make a high-pitched whining or droning sound; it can happen continuously, when you perform certain tasks on the computer or when you take the power load high enough. This can happen either because of cheap construction or because the unit is too close to maximum capacity. As you would do to check the fans, open the side panel while the computer is running and put your ear up to the PSU. If this is where the noise is coming from, replace the unit with a high-quality model and upgrade to a higher power output if you need to do so. Hope this helps.
Jan 08, 2013 | Acer Aspire Z3100 (2771498) 21.5 in. PC...
Acer aspire x1700 black screen, makes high pitched noise, doesn't respond
You may have damaged or dislodge a component.
I suggest you remove the cover and reseat the RAM modules and all the cards in the expansion slot (unscrew them pull them out of the expansion slots and insert them back then secure them with the screws.
If it still does not boot up then you need to take the computer to a computer repair shop.
Mar 11, 2012 | Acer PC Desktops
I have an Acer Aspire with Realtek HD Audio Manager. When I run a test on the control panel, the speakers transmit sound properly. However, anything I've tried to use recently like itunes or sound from the...
I had the same problem a few months ago, i also looked to see if i saw a mute function that was active anywhere.
I did not find anything so i just reinstalled the application and my problem was fixed. At the link below you can find the realtek audio app. for xp and vista.
Please rate this solution
Best regards
Sep 14, 2009 | Acer Aspire™ T180 PC Desktop
Sound problems
Try to install updated audio codec for that matter. Go to this link:
  • Two similar links will appear. Choose the link under the orange colored Download XP Codec Pack 2.4.6.
*Drop me a comment and i will assist you. I hope this will fix your problem.
Best regards
Jan 24, 2009 | Acer Aspire™ T180 PC Desktop
Audio not working and bought the computer with sound
Audio not working means there must be a driver problem.Try to install the audio driver again.If it is high Definition audio driver first uninstall audio driver and high definition audio driver package.Reinstall the driver again.if problem persists check for the audio port.
Jul 05, 2008 | Acer Aspire™ T180 PC Desktop
Ethernet Port failure on Acer Aspire T180-GB7Z
Type of your O.S (Operating System) Windows, MAC, Linux Etc?
May 12, 2008 | Acer Aspire™ T180 PC Desktop
PC is hang up about 5 mins after boot up.
heat sink problem or
ram problem
re assemble the system
Oct 26, 2007 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
213 people viewed this question
Top Acer PC Desktops Experts
Brian Sullivan
Brian Sullivan
Are you an Acer PC Desktop Expert? Answer questions, earn points and help others
