SOURCE: WH95TP-03, won't make ice
The machine in let water filter is block clean the filter and check the water flow
SOURCE: I have a u-line ULN-WH95TP-03
It has water supply but solenoid will not allow water to enter the mold.--------
You are correct, this problem is faced by many others too.The solenoid valve by times gets worn out and it sticks/clogs.The solenoid valve needs to be replaced.
The water supply line is connected to the line to the solenoid valve.
Replacing the valve should help.Thanks.Helpmech.
