Problem with tv
Watching tv and picture went to a line across the middle of the screen, sound ok does this mean a new tv or can it be repaired line across the middle of screen sound is fine, did dust on the back of tv have anything to do with it?
  • jmontejr Mar 01, 2008
    my set has sound and you can see the remote functioning even in the thin line across the middle of set.full picture does not come back?
  • Warredg May 20, 2008
    Same problem. After 10 months of usage the screen works fine for the first few seconds of operation then collapses to a small horizontal line. Would a new power supply solve the problem?
    Thanks,
    Don in St Louis
  • 67 Answers
Its known as 'screen collapse' and yes it can be fixed but it may not be economical you should get some quotes from your local tv repairers.
Posted on Nov 15, 2007
The picture went out on my TV
This is not a user repairable issue and would require a TV repair shop. You may want to consider a new flat screen TV before spending the money on repairs.
Mar 02, 2015 | Televison & Video
LG 32LH30 LCD TV Problem
IMO Seriously for $119 it's not worth it.
However, it does sound like a capacitor problem
If you are "Serious" about fixing I'd find a TV repair Forum.
Else I'd go here and get a new one.
https://www.walmart.com/browse/electronics/32-inch-tvs/3944_1060825_2489948_7156390
Best Wishes.
Apr 29, 2017 | LG 32LH30 32 in. LCD HDTV
You can be watching suddenly the picture goes out but a very narrow line across the middle. It still has sound.
The vertical deflection unit is faulty. The tv must be repaired by a professional.
Jul 05, 2010 | Televison & Video
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Problem with tv
The problem is sometimes caused by the vertical output integrated circuit (IC) failing, but usually it's bad solder connections. If you or someone you know is comfortable with electronic soldering, a few minutes spent resoldering the IC pins to the circuit board will often solve the problem. Failure of these connections is common because the IC gets quite hot (and it's mounted on a metal heat sink). The heating and cooling cycles cause the solder joints on the circuit board to crack. You can usually see the trouble with light and a magnifying glass; gray grainy joints instead of shiny connections, and often visible ring cracks around the pins.
Mar 31, 2009 | Konka K1938U 19" TV
My TV Doesn't have any picture???
This is what is known as frame collapse - which means there is no vertical deflection applied to the tube.
Please do not continue to watch the set in this condition as it may burn a horizontal line in the middle of the screen.
The most likely cause is either bad solder connections to or failure of the frame vertical output IC.
Please rate the assistance I have given - I hope it is useful. If you call a serviceman and tell him its frame collapse as this type of repair is not for amateurs - voltages in television receivers can kill.
Mar 19, 2008 | Televison & Video
Problem with tv
Could be a horizontal output fault, faulty power supply, a simple dry solder joint or HVT. If you can hear arcing or smell an ozone odour, it will be the HVT which may cost a bit.
Without knowing the actual cause, it's impossible to say how much it would cost to fix it.... could be anywhere from $50 to $250 etc
Best to have it checked by a technician and get a quote to repair... then decide if you think it's worth it.
Toshiba is generally a reliable brand, so if you were happy with the picture quality before the fault occurred, it's probably worth repairing.
Cheers
Jan 05, 2008 | Toshiba 36A41 36" TV
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
Pls more info; what do you mean tv on, picture froze? you are watching on tv chanel, do you use cable? I can help you but need more details.
Aug 29, 2007 | JVC AV-32D305 32" TV
Problem with tv
Hi. No this is a run of the mill fault not that complicated. Repair shop should be able to repair with out any problems.
Aug 28, 2007 | Toshiba 28N33 28" TV
Televison & Video Logo
278 people viewed this question
Top Televison & Video Experts
