Question about InFocus Proxima DP6155 Multimedia Projector
Color Alignment We're having a problem with a ceiling mounted projector. The RGB signal seems to off, the colors are out of alignment on the left side of the screen. This alignment issue shows up when using the video input port or the computer port on the projector, also we swapped cables, so that leaves the projector.
  • dpdummy Mar 08, 2008
    I have the same problem with color alignment and would like to adjust it myself if anyone knows how
  • 2,237 Answers
Reset the settings to factory default. then re-solder the fingers on the edge of the power supply board where it goes into the main board edge connector.
Posted on Dec 29, 2009
Colors out of alignment Epson EMP 500
You LCD optical engine is out of alignment. This will require an authorized service center to make the adjustment or even replace the unit if necessary. There are 3rd party companies that offer this service, perhaps in your own town or nearby. You may want to weight the cost of repair to purchasing a newer unit.
Jun 04, 2009 | Epson EMP 5500 Multimedia Projector
How to reset nokia mobiles life timer to ''0''
Nokia life timer is a counter that keeps track of the Total call time of your phone. It will show how much the phone has been used, and it?s the best thing to check if you?re planning to buy a used Nokia Mobile.
To see the Total Call Time or the life timer counter, On the standby screen type the following code *#92702689# (Easy way to remember this is ? *#war0anty#). And it will pop up a message that shows the life timer in hours and minutes.
Here is a detailed procedure to make this life timer zero.
The following files are required to reset the life timer:
  1. Nemesis service suite link: Download from Here
  2. file: Download Here
1. Download and Extract the file, and Download Nemesis Service Suite.
2. Install Nemesis Service Suite on your Computer, It won?t take much time.(select the first option)
3. Install Nokia Cable Drivers (No need to install, if you have Nokia PC Suite already installed)
4. Connect The Phone in ?PC Suite? Mode to the PC
5. Open Nemesis Service Software
6. Click on ?Scan for new Device? Button on Top right Corner
7. It Will take a few seconds to scan, and it will load up the software interface after communicating with the Phone.
8. Click the ?Phone Info? Button.
9. On the Bottom, Select and open the ?Permanent Memory? Tab, which is next to the Fbus info.
10. Click the ?Write? button on Below right, and open the Extracted file on your PC.
11. After the file is opened , it will immediately start writing it to the Phone?s EEPROM Area.
12. The Procedure will end when the progress bar reaches 20%. This is normal , and on the bottom right side, it will display its done.
13. Unplug the Phone, and Restart it.
14. After boot up, Check the life timer .
Note: This method has been tested on following devices: Nokia 6630, 6670, 6680, 5500 sport, 5700XM, 6110 Navigator, 6120 Classic, N70, N72, N73,N76, E50, E51, E61i, E65, N80, N91, N95, N95 8GB, 5800XM Mobile devices. If you want to try it on other S60v3 or S60v5 mobiles, do it at your own risk.
  • Power Failure During Writing will cause damage to the Phone, And there is a chance that it might brick the phone as well.
  • Loose, worn out Data Cables Might fail the Writing process, and there are chances of damage to the EEPROM area of the phone.
  • Do not attempt this with phones that are not included in the confirmed list.
By:- Mohammed Abdulhadi
on Jun 21, 2010 | Cell Phones
Slight RGB alignment problem
Please describe the allignment problem
Apr 19, 2008 | Philips ProScreen 4650 Multimedia...
Color difficulties
Have you tried using the video inputs, Is it able to show red then ?
If not & you have reset the factory settings the prisim or mirror's may have gotten out of alignment in shipping, Or it may have a bad lcd panel or the red lcd may have a bad connection or driver circuit.
Feb 13, 2008 | Office Equipment & Supplies
How do I align the color on an MT850
pls check the board before the color wheel, as it is noticed that this problem comes with the main PCB Board.
Nov 19, 2007 | NEC MultiSync MT850 Multimedia Projector
Color alignment is off
i also have the exact same problem. i picked up 3 of these used for my work and kept one at home. I knew one had issues and another had a burned out bulb and so on. I had a repair place to combine the two to make one good one. The repair man said that they had a real hard time keeping the color locked in alignment. It's not a physical alignment, its controlled by the board output and somehow the board can be adjusted. It was vague to me. After about a good couple of years of hard use the one at home is now doing the same. On one hand I want to fix it but I dont even have a plasma so I may go and spend $800-$1000 on a hi def DLP. At that price it won't be the best but it will rock this projector. that would be my advice rather than putting more money into this old model.
Aug 06, 2007 | Philips ProScreen 4600 Impact Multimedia...
Projectors display
the lcds areout of alignment. you'll need to send it in to a service center to have them do it. you can try yourself, but you may need special tools.
Jan 04, 2007 | Boxlight SP 5t Multimedia Projector
InFocus Proxima DP6155 Multimedia Projector Logo
665 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
