Question about Samsung HCN4226W 42" Rear Projection HDTV-Ready Television
Tv is dead
Can you tell me what might the problem with my samsung HCN4226WX/XAC Projection TV.When I press the on /off switch the 4 leds lights up and blinks for 6 times then stops the tv as no sound or pix.Could this be caused by a bad convergance board.
Thank you
  • 2 more comments
  • stinah Nov 15, 2007
    I also have a Samsung HCM4215W 42 in but it's totally not working, when i switch on the power light come on briefly and goes off. I have been told to buy a new PCB & convergence board, do you think this could be the problem??
  • Freeman Nov 28, 2007
    Thanks diode99 you were of a great help I plan to buy a new ic chip this weekend and install it.I will follow up with the results.
    Thanks again
    Thanks for the heads up regarding the fuses and the resistors.I don't have a schematic ,can you tell me what the fuse numbers/ resistors are that need to be checked. I did a visual check around the chip but its not that easy to check the inputs and outputs of the chip without a designated #.
    Thanks for help
  • Anonymous Dec 03, 2007
    I was watching the
    TV then the picture and sound quit and will not come on.
    HDCN4226W now it won't even come on.
  • 4,402 Answers
Im thinking convergance ic
· Samsung parts for convergance problem
Posted on Dec 18, 2007
    Problem Solver:
  • 5 Answers
Hi, Yes! the convergance board can stop the unit from coming On. No need to change the board, just change the ICs. This is what it looks like,you will have to remove the board from the unit take note of the wires before removing them, -Tv  is dead - 794a500.jpg
Posted on Nov 27, 2007
  • Hollis Smith
    Hollis Smith Nov 28, 2007
    Thank you; one more thing, you will need to use a tester , to check some very small fuses and low value resisters. On the same can do it.
  • Hollis Smith
    Hollis Smith Nov 30, 2007
    Hello missileman,
    Okay the fuses are what we call micro fuses, you will see some on the main board.....they maybe colored yellow or green, people takes them for resistors, next to it you will see F801 and so on . The resistors are standing up on the board with the STKs, and they are going to the IC pins, check all of them....the first thing , is to put in the ICs, maybe that's all you.
My tv trys to turn on several times but will not, I checked the trouble code tells me its the lamp . I took the back cover off I can see the lamp starts to come on but it shuts down and trys to restart...
Tv "LAMP" LED light is flashes or stay lite?The tv Projection lamp been in ur tv like 1 1/2 or 2 and tv been on and uses it like 4 or 5 hours daily?Yes tv projection lamp is dead and also might the board that call the Ballast board it dead too.This Ballast board,that board job is to help to ignite the tv projection lamp.
Jan 31, 2011 | Toshiba 52HM95 52" HDTV Projection...
Turn on lamp blinks several times.lights up but no any remote button timer in green turns off and goes to standby
The tv "LAMP"LED light indication flashes or stay lit?The tv projection lamp been in this tv like 1/2 or 2 years?Tv been on and used like 4 or 5 hours a day?Yes,than the tv projection lamp life are over.Require a new tv projection lamp.
Nov 17, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
Samsung TV: lamp out
Yes,tries websites like,, to buy a projection lamp for the replacement.Tv have "LAMP"indication LED light is flashing or staying on.If the projection lamp on the tv now,been in used 4 or 5 hours a day watching the tv.The projection lamp has not been replace the last 1 1/2 or 2 years on the tv.The projection lamp life is over,require changing.The tv also making clicking noises,the Ballast board also dead,require changing too.The Ballast board help to ignite the projection lamp.
Aug 02, 2010 | Samsung HLP4663W 46" Rear Projection HDTV
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
How do you configure the red convergence for the samsung hcn4226wx/xac- getting the red screen but will not allow to line up
CK 2 resistors on STK convergence Board 2.7ohms if open/bad replace them - then you should be able to adjust convergence.
Nov 22, 2009 | Televison & Video
2003 Samsung HDTV 1080i 42" wide screen has just developed picture problems distorted and red. Almost looks 3D. MODEL NO.:HCN4226WX/XAC SERIAL NO.: 37083CEX400297E
This is a convergence problem and can easily be fixed either by resoldering the pins on the convergence ICs or by replaceing them if they prove to be defective. Can you solder? Do you feel confident in replacing these parts?
Keep us posted.
Jun 04, 2008 | Televison & Video
2006 42'' Samsung rear projection, Balist????
A Ballast is a circuit that provides voltage to Lamp. Ballasts are only used with TV's with a Lamp. According to your model number this unit does not use a lamp. That model number uses 3 rear-projected CRTs. The most common units with a ballast would be a DLP HDTV.
The Model number you specified HCN4226W is a unit made in 2003. However you stated in your subject line that this was a Samsung unit from 2006. Please verify your model number.
Feb 29, 2008 | Samsung HCN4226W 42" Rear Projection...
42"Samsung HCN4226WX/XAC
Oct 09, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung HCN4226W 42" Rear Projection HDTV-Ready Television Logo
163 people viewed this question
Jerry Greenberg
Jerry Greenberg
