Yamaha 2005 Big Bear 400 4x4 Logo
Michael Pate Posted on May 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
07 Yamaha Big Bear 400 4x4. How can I replace the stator and flywheel without using special tools?
Steve P
Level 3:
  • Yamaha Master 3,912 Answers
  • Posted on Jun 11, 2017
Steve P
Yamaha Master
Level 3:
Answers
3912
Questions
5
Helped
1305753
Points
15904
You need the special tool... it is designed to prevent damage to anything else and get it off quickly, Do your self a favor, get one or take it to the dealer and pay them to pull it.. if you break something.. OUCH,,, all that stuff is VERY EXPENSIVE!!
5 Related Answers
tombones
  • 3567 Answers
  • Posted on Apr 03, 2009
SOURCE: yamaha big bear no spark
I'm not familiar with all quads and all the kill switch locations. Does it have a tip-over kill switch? Is it working? Is the quad in neutral? Is the neutral light on? Many engines will not spark if the neutral light is not on. Are the headlights off when starting?
How good is your battery? A low battery can kill spark. Test for spark by grounding the threads of the plug against the cylinder. Have a friend kick the bike while you watch for spark. Assuming no spark, then check all the kill switches with an Ohmmeter to be sure each switch is working properly. Sometimes a switch goes bad. Try disconnecting all kill switches then check spark.
Check the wiring harness, even under the gas tank and seat. Are all the connectors clean and with a tight connection? Any abraded wires? Check the ignition switch also. The switch can go bad as well. Are the flywheel coils good > is the battery getting a charge?
Still no spark? If CDI then get it checked.
If points then file or replace them along with a new condensor and reset the gap then time the engine. >> I hope this helps.
Please rate this answer. Thanks trsrhntr!
Anonymous
  • Posted on Apr 09, 2009
SOURCE: 1989 yamaha big bear no spark
ay how u doin
one thing u can do is check the magnito
if tats fine then check the spark plug
located on the front part of the engine
co7196
Ned C Cook
  • 3433 Answers
  • Posted on Jun 20, 2009
SOURCE: no front brakes on 95 yamaha big bear atv
gravity bleed. make sure fluid is always full. crack open the bleeder screw and let the brake fluid drip until no bubbles. Then close bleeder top off fluid and replace cap. Now, pull the brake handle. If there is no pressure or has bleed down, the master cylinder is kaput.
pwrman
  • 19 Answers
  • Posted on Aug 21, 2009
SOURCE: yamaha big bear 400 will
Sounds like a problem with the starter, could be a starter fuse, relay or solenoid. The start cicuit wiring could also be damaged. If you can pull-start the motor, and it runs fine, you have pretty much eliminated any problems with the motor. Check the wires running from the start button make sure they are intact, also trace them and look for around a 1" cubed black box. This is the relay, when you push the button, if its working, you will feel the box click. Also locate the starter and do the same thing. If you feel or hear the starter click, the solenoid is working. The battery voltage could also be too low to energize the starter motor. Could also be a battery or alternator issue. Check the battery voltage and for any sounds coming from the bike when you push the start button.
Anonymous
  • 149 Answers
  • Posted on Aug 31, 2009
SOURCE: owners manual 2001 yamaha big bear 4wd
http://www.carlsalter.com/motorcycle-manuals.asp
Can I fit a new stater wrong Yamaha big bear350 ignition timing seems off spark not good only sparks with ignition OFF
IT is not possible for you to fit stator,,, the reason is casing flange bolt will not correct with engine casing,,,,...it will different with various manufactures
2005 Yamaha Big Bear 400. How do I replace rear brakes?
Removing The Rear Brake Drum & Shoes on Grizzly 600 ...
? 5:04
www.youtube.com/watch?v=n5oO7v3nT6s
Mar 11, 2012 - Uploaded by myquadrepair
Removing the rear brake drum & shoes on Yamaha grizzly 600. ... Yamaha Big Bear Oil Change and More! - Duration: 10:43. by jfrost77hd ...
HONDA FOREMAN REAR BRAKE CHANGE PART 1 ...
? 11:49
https://www.youtube.com/watch?v=xQanZdlDCI0
Jul 17, 2012 - Uploaded by 400EX99N
HOW TO CHANGE REAR BRAKES ON A HONDA ATV. ... is this about the same for a 2004 yamaha big bear 400? Read more Show less.
Nov 03, 2015 • ATVs
1helpful
Flywheel removal yamaha big bear 400
impact wrench, gear puller.
May 24, 2015 • ATVs
2007 Big Bear. Where can I find a video showing removal of the flywheel?
You need a Yamaha special tool to remove the flywheel.. the local dealer should pull it for you..maybe a minimum charge or buy the guy a beer or coke,,(I charge a 20oz. coke)
I have a 07 Yamaha Big bear 400. How do you remove the magnito and flywheel without specialty tools
You don't they are on a tapered shaft with a key way. If you must try you can tap the flywheel around the edges. As you try levering the inside edge outwards on opposite sides a little at a time.
If you try this you take a big chance of damage to the shaft and engine cases.
May 24, 2015 • ATVs
Stators
you will need a special flywheel pulling tool be sure not to use a impact or a hammer when doing this it can damage the flywheel
Yamaha Big Bear will not crank and start. replaced solenoid, battery, cleaned carb ... new plug, traced all wires. help!
Smack the starter with a hammer or a wrench if the starter isn't turning over then it's bad if it does crank and won't start your CDI may be bad you've all ready replaced the little stuff sounds like it your starter is bad hope it not CD I if it is replace the stator as well and buy them on ebay it will save you a ton of money
If you need further help, I’m available over the phone at https://www.6ya.com/expert/brandon_79b580f5a99c4386
Top Yamaha ATVs Experts
ADMIN Andrew
ADMIN Andrew
Arnie Burke
Arnie Burke
john h
Are you a Yamaha ATV Expert? Answer questions, earn points and help others
