Question about Compaq Presario 2100U Notebook
Pc laptop going onto start none of my programs run
    Genius:
  • 1,601 Answers
Go to safe mode and run system restore.
Posted on Nov 14, 2007
Hoe to delete programmes?
If you are on a Windows machine you would go to Start, Control Panel and Programs and select Uninstall a program than select the program you want to uninstall.
Aug 18, 2014 | Computers & Internet
I have problems with my windows 7 physical memory running very high (when none action is in progress) (ACER ASPIRE)
Check how many programs your laptop runs at startup.
There is a little icon next to your battery meter looking like this ^ click and see how many programs are running in there. You can also go onto your Control Panel and look for "Perfomance Information and Tools" it'll walk you through speeding up your computer no end.
And get Microsoft Security Essentials instead of NOD, it works in harmony with your OS and does everything you need to keep your PC safe.
Aug 16, 2012 | Toshiba Computers & Internet
Getting message from computer
To run DVDVideoSoft you will administrative right to your PC, if you have administrative right to your PC.
Start DVDVideoSoft by Right Clicking on DVDVideoSoft and selecting Run as administrator
Dec 06, 2011 | Microsoft Windows Vista Home Premium...
There is a fake anitvirus 2010 that has infected
Out of all of those solutions for the antivirus virus the only solution that I have found to work was to download a program called Malware Bytes. you can google search it or download it from cnet.com. Other then that the only other way to fix the issue is to format your hard drive
May 16, 2010 | HP G60-235DX Notebook
It made a noise then it turned off, now it will not turn on and also the charger light does not come on
Sorry to hear about your problem. Lets see what we can do to get you back up an running...
If your computer will turn on then turn off try this:
OK. First go here Then go HERE
The first download is for Utorrent2.gif, a very small bittorrent program.
The 2nd is for the program that will fix this problem for you.
After installing Utorrent (or skip if you already have a torrent program) Go to the 2nd link and start the download of Spinrite.
Once the program is completely downloaded, virus check it.
Burn Spinrite onto a disk
Go the to the machine with the problem and load the disk.
Insert disk and Reboot system
Run the program at Level 5 not the default which is 2.
After letting the program run in its entirety remove the disk and reboot. you should be ready to rock..!
If your laptop is DEAD (you hit power button and nothing happens at all)
1. remove battery and plug into AC power - try to start
2. try starting with only battery installed - no ac plug
if none of this works it sounds like your Power supply has puckered out. IF this is the case I would visit the manufacturers website for information on replacing it.
Oct 17, 2009 | Acer Aspire 5500 5570-2609 Laptop
I need to know how to download the program onto my laptop that has the Vista program.
if you right click the installation file and click properties then click compatibility then click run as windows xp it might install that way
Apr 19, 2009 | Computers & Internet
Slow to boot (10-15 minutes)
A couple of different fixes you can try.
Go into Control Panel | Add/Remove Programs. Remove/Uninstall any unused or unknown programs.
Start | Run | Msconfig - On General tab, select "Selective Startup" and uncheck "Load startup items". Reboot computer. If computer boots faster (and daughter's profile works), then go back into Msconfig, select "Normal Startup", go to Startup tab, and start unchecking programs to slim down what loads when computer starts. Note: NONE of the programs in Startup tab are NEEDED for windows to run, but some of your applications may need them.
I'd also recommend getting a good Anti-Virus/Anti-Spyware package to make sure no viruses or trojan horses are on it.
Apr 06, 2009 | Dell Dimension 4700 PC Desktop
Software wont work on vista
The omnia runs on windows mobile, so it sync through activesync, but I suppose you already know that.
To install software/applications onto the omnia, you have to install via the pc, IF the file is a supported .exe or .msi installation file to install the program components onto you PC.
If you have software in the form of a .cab file, it must be run from the omnia. So you have to go to My Computer>Mobile Device> and then put it in your phone, then from your phone, run the .cab file.
Basically, if it doesn't work on vista, put it on the phone and try running it through the phone. Also, if you dont know, you go to start>programs>file explorer (on the phone) to find the file and run it.
Feb 28, 2009 | Samsung SGH-i900 Omnia Unlocked Cellular...
How to open a terminal. (On my acer aspire one)
What do you mean by terminal?
Hyperterminal connection to a switch? - It's in Start - All programs - Accessories - Communications - Hyperteminal. You will need to know the com port number and associated other settings. Try 9600, 8, none, 1 with flow control None
A physical port on your laptop? - there are screws on the underside of the laptop that can be undone to reveal compartments, or flaps on the side of your laptop that can be simply undone by hand.
A remote desktop connection? - using microsoft terminal services connection. Click Start - Run then type mstsc and hit enter. Enter the IP address or host name of the system you want to connect to.
Nov 09, 2008 | Computers & Internet
Dell Laptop/itunes
first check if the service is running
-click start, run (or hold winkey+r)
-type services.msc
-look for "apple mobile device", right click it, select properties, start up type should be automatic, and start the service if not already done
that should work
Jul 13, 2008 | Computers & Internet
Compaq Presario 2100U Notebook Logo
22 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
