Question about Midland M222P (22 Channels) 2-Way Radio
Midland 77-099 cb radio
I have a problem with my radio keep going back to channel 9 for no reason
Re: midland 77-099 cb radio
All the CB radios will turn on by default on Chanel 9, check for connections that could push the radio to turn on and off intermitent.
Posted on Nov 19, 2007
    Problem Solver:
  • 12 Answers
Ok if your useing the radio on the cigar lighter socket and disconnecting it all the time it will by default go back to ch 9 its not a fault they were designed that way
  • 27 Answers
When does it do this?
Posted on Nov 15, 2007
0 characters
3 Points
On this model #75-509 what is maximum distance for comunicating
I think that is a 1 watt radio. In optimal conditons you should be able to get a 3/4 mile solid, maybe a bit more. In a not so great situation, such as woods or buildings in the way about 1/2 mile or a little less.
Feb 07, 2016 | Two-Way Radios
I Want To Add Talk Back Mod To CB Radio
there is what is known as the Quick and Dirty way, to add talkback to almost any CB radio. You will need a 130 Ohm 1/4 watt resistor. Open the radio and find the two mounting points for the external speaker jack and PA audio jack, you will want to solder the resistor across from the Positive connection of the PA jack to the Ground connection for the External speaker jack. This will give you talkback, and eliminate any feedback when the microphone is held at a normal operating distance away, Just remember, (This could potentially damage your radio if done improperly, I will not be held liable for anything that you do to your radio.) However, when done correctly this is a perfectly safe modification, and will allow you to monitor your output audio, as it is being transmitted. You can adjust the size of the resistor to your liking, however, I do not recommend anything lower than 100 Ohm, as there will be more potetial for squealing/feedback.
Feb 20, 2014 | Midland Radio Midland 9001Z Citizen Band...
Need a repeater for 75-822 Portable/Mobile CB
there are no repeaters for CB radios, they are not legal, nor Are CB's capable of using them.
Oct 08, 2013 | Midland Two-Way Radios
Walkie talkie frequencies
The Midland LXT328 is a FRS/GMRS radio and can communicate on 22 different frequencies. Here is a list from radio reference:
1 462.5625
2 462.5875
3 462.6125
4 462.6375
5 462.6625
6 462.6875
7 462.7125
8 467.5625
9 467.5875
10 467.6125
11 467.6375
12 467.6625
13 467.6875
14 467.7125
15 462.5500
16 462.5750
17 462.6000
18 462.6250
19 462.6500
20 462.6750
21 462.7000
22 462.7250
Sep 11, 2013 | Midland LXT328 Two Way Radio
I have 4x Midland GXT 600's and I am trying to tune them into my mates Motorola 2 ways, he is hos on channel 5 subcode 25. Now for some reason when I try to get on the same channels I can not hear him. I...
Motorola FRS radios works with CTCSS or DTCSS and Midland Calls them Privacy Codes, try first using Code numer Zero wich is no code or code off, of course at the same channel in all radios. if you can heard all radios the next step is to choose a code, Im sure that the first code numers in both radios must be the same
Feb 01, 2010 | Two-Way Radios
Cb radio doesn't give out any sound
You would be surprised how little people actually talk on CB radios these days. I went through similar struggles a few years ago. Unless you are in a major trucker area, the CB radio is basically silence.
Check out the weather channels (anything on the WX setting) to make sure that your radio is receiving frequencies correctly. If that doesn't work, then it is your box, but I bet that will work.
Oct 30, 2009 | Two-Way Radios
How can you talk to cb radios?
with another CB radio only. A midland 2 way radio is gmrs and is a much higher frequency then CB. not compatible.
Sep 25, 2009 | Midland LXT310 2-Way Radio
Can't figure out how to get a "channel" to lock on the handset
Here is a link to the owners manual for the LXT-330 420 Series radio: Owners Manual.pdf
I hope this helps.
Mar 27, 2009 | Midland LXT410 (14 Channels) 2-Way Radio
How do you unlock the channel?
Press and hold the Lock key for 5 or 10 seconds until a beep sound is heard.
Good luck
Oct 23, 2007 | Midland M222P (22 Channels) 2-Way Radio
Midland M222P (22 Channels) 2-Way Radio Logo
157 people viewed this question
Top Midland Two-Way Radios Experts
Level 1 Expert
Are you a Midland Two-Way Radio Expert? Answer questions, earn points and help others
