Question about Dryers
GE dryer starts but..... stops
Dryer starts when start switch is engaged but stops immediately on release of switch - I.E. must hold switch on for dryer to operate
  • 248 Answers
Re: GE dryer starts but..... stops
The motor switch is not working properly. You can try removing lint from motor area around the end where the wires attach. This may free switch. If it still won't work you need a motor.
Posted on Nov 15, 2007
0 characters
3 Points
Start button starts dryer and dryer stops when button is released.
Ge dryers have a belt sensing switch inside that won't let the dryer run (just as you describe) when the belt breaks or comes off. My guess is you broke a belt. With door open---hold in button door switch and hit the start switch to get it too run a few seconds. Watch the drum and see if it turns. My guess it will not. Belt is a long skinny band that goes all around the drum outer area and then down around the motor.
Jul 09, 2015 | GE GTDP180GDWW Gas Dryers
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Ge electric dryer dpsr483ea1ww, dryer stops when start switch is released
Broken belt or broken belt switch or broken wire or bad motor.
Sep 05, 2012 | GE Dryers
When I the start the GE dryer it will not start unless I will Hold it to On position. when I release it it will other words it will not hold to Run position
you could have a bad motor. the motor has an internal switch that is stuck in the start position and not switching to run. replace the motor.
Feb 05, 2011 | Dryers
I have a model dwsr483eb1ww ge dryer that will start and run as long as hold the start switch. when start switch is released it stops.what would cause this?
Sounds like the start switch is faulty.
Try replacing the start switch, this may solve your problem.
I will include these two websites for parts and further help:
Both also have chat assistance 24/7.
Good Luck,
Hope this helps
Nov 05, 2009 | GE DWSR463EGWW Electric Dryer
Dryer won't stay running
I had the same problem with my kemore. Thank goodness I still had it under warranty.
The tech said the door latch was just slightly ajar. This is common he said that when we take clothes out we let the door close to hard or gets ajar for leaning in to take clothes out.
He readjusted it and I have never had a problem with it again.
Hope this helps
Sep 26, 2009 | GE DBSR453EBWW Electric Dryer
GE dryer must hold start button to keep dryer running
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
Jun 20, 2009 | GE 5.8 Cu. Ft. Extra-Large Capacity...
Dryer stops when I release the start rotary switch knob.
This sounds all right on the short term. But eventually it will go out. to replace the part is not that expensive or hard to replace.
Jan 23, 2009 | GE DBSR453EBWW Electric Dryer
Dryers Logo
474 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
