Question about Dual XDMR7710 CD Player
Buttons don't do what they are supposed to.
Some of the buttons on the player don't work correctly. For example, when I press the eject button, it changes the band of the radio. Another example is that when I press the radio preset number one, it goes to preset two.
  • 1 more comment
  • Anonymous Jun 25, 2008
    I have 2 of the same radios that do the same thing.
  • matthewearos Oct 28, 2008
    Mine is doing the same thing. The Eject button changes the stations, the power button won't work at all. Does anyone have access to the internal wiring diagram for this? I'm pretty sure it's a short going to the faceplate (all commands off the remote work as advertised).
  • Anonymous Mar 01, 2009
    Sanme ****, I'm going to try and look into it a little further.
How to set clock
Posted on Mar 30, 2008
Is there a way to get the disc out without dismantling the entire TV? Disc is stuck, lock icon shows when eject button is pressed. Can TV be reset to factory specs?
Try the following. kindly update result here in comments
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Mar 21, 2016 | Toshiba Televison & Video
Tip
How to program your RM-V310 Sony Universal
Step 1: Entering the Code Number
1 See the supplied "Component code numbers", and find the threedigit
code number for the desired component.
If more than one code number is listed, use the number that's
listed first to complete the steps below.
For example, if you're setting up a Philips' VCR, you would use
the code number 035.
If your component isn't listed, see "Searching for the Correct
Code."
2 While pressing the SET button, press the
POWER button.
3 Press the button of the component that
you want to set up.
Note
On the VCR, CBL, SAT, AMP, CD, and DVD buttons, "video cassette
recorder", "analog cable box", "digital satellite receiver", "receiver",
"CD player", and "DVD player" are assigned respectively at the
factory. But you can also assign other components on these buttons.
For details, see "Changing the Component Type on the VCR, CBL,
SAT, AMP, CD, and DVD buttons."
4 Enter the component's code number.
For example, if you're entering the code
for a Philips VCR, you would press
5 Press and release the ENT button to store
the code number in the Commander's
memory.
6 Go to "Step 2: Checking if the Code Number Works" to finish
setting up.
1 Power on the component you want to set up.
2 Aim the Remote Commander at the component and press a button
to check if that button works.
For example, press the POWER button to see if it works on your
component .
3 Check that the other buttons of the Commander is operating the
corresponding functions of the component.
You can write down the code number on the label inside the
battery compartment lid.
If the Commander Doesn't Seem to Be Working...
• First, try repeating these setup procedures using the other codes
listed for your component (see the supplied "Component code
numbers").
• If - after trying all the codes listed for your component - you still
cannot get the Commander to work properly, try the search
method described in "Searching for the Correct Code."
These instructions came from the Sony RM-V310 Operating Instructions Manual. To Download the Full manual for FREE click HERE>
on Oct 07, 2010 | Sony RM-V310 Remote Control
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray DiscĀ® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
If press eject button,it's showing LOCKED.what can i do?
Jan 21, 2015 | home Audio Players & Recorders
Buttons work intermittently?
Used products usually are discarded for problems . not fixable usually
May 22, 2017 | Aastra Telecom 9116 Corded Phone
Cd compartment wont open and it is locked dvp sr200p sony
Ensure the child lock feature is disabled. Try Power resetting the Player.
Turn Off the player and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation.
If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons.
If the issue still persists, service might be required.
Jul 26, 2010 | Sony DVP-SR200P DVD Player
I have a CD jammed in my VW Beetle 2005 player. I
Most CD players have a reset button.looks like a very tiny depressed button...push it while you press on the eject button.
Jan 02, 2018 | Volkswagen New Beetle Cars & Trucks
I cannot get the CD player to eject the CD. the radio is a standard AM/FM radio with a CD player in a 2005 Ford explorer XLT. after pushing the eject button the radio screen blinks ''EJ err''. The cd...
Turn the radio off first and then disconnect the battery for 2 min then reconnect the battery. This should reset your radio and then you can eject your CD, and reset your stations and clock. Good luck
Sep 30, 2009 | 2005 Ford Explorer
Need remote code for 22lv505 for dish network
Your code is 750....... Program the remote control in TV mode and then in VCR **repeating the steps** (or AUX - press 1 before entering the DVD code) mode.
How to program your dish network remote for your tv:
1. Use the device’s buttons or its remote control to turn on thedevice.
2. Press and hold the mode button for the device you want the remote to control, for about three seconds. When all the other mode buttons light up, let go of the mode button - that mode button should now be flashing. For example, hold the TV mode button for a TV until all of the other mode buttons light. When you let go, the TV mode light will flash.
3. Only for the AUX mode, Use a number button to enter 1 for a second VCR or DVD player
4. Use the number buttons to enter one of the device codes that I have given you.
5. Only for Limited Mode, Press 1.
Limited Mode- allow you to only use the remote to Power, Mute, and adjust Volume on your tv.
You cannot change the tv channel when the remote is in limited mode. You can only power on your
VCR in limited mode
****Note: Skip this step if you do not want to use Limited Mode.****
________________________________________________________________
6. Press the POUND (#) button. If you entered the code correctly, the mode button flashes three times.
7. Press the blank POWER button to test if the code works for the device. If it does, the device should turn off.
8. Turn the device back on and try some other buttons to make sure they work. Sometimes, the blank POWER button works when other buttons don’t. If the code works for other buttons
** Stop Here**
Let me know if this helps..
1388f48.jpg If I have helped you, dont forget to rate!!!
Jan 03, 2009 | Toshiba 22LV505 22 in. LCD TV
CD Player won't work
Try pressing the eject and load buttons at the same time, with the car ignition in the ON position. You might have to hold both buttons for 15 to 30 seconds for this to work.
Oct 26, 2008 | 2003 Ford Focus
Dual XDMR7710 CD Player Logo
132 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
