tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light. Ple help me
5 red flashes is a bad panel connection or internal panel short, very carefully take the panel connectors off and reseat them and see if that helps, unfortunately you may have a bad panel.
You need to check the charging system. Take a volt OHM meter and go to the positive and then the negative posts. It will tell you how many volts it is putting out. If it is not charging at least 13.9 volts, then you bought a faulty alternator. If the alternator is good then check the belts to make sure they are tight enough. When you push on the belt at about 3 inches from the alternator it should not give more than 1/4 to 1/2 inch. If it does move more, then tighten the belts. If it is a V belt, just tighten the alternator. If a serpentine belt, check the belt tensioner and belt routing to make sure it is on right. The diagram should be under the hood.
The TV shutdown error code can help you with this problem. If the power led flashes green for 2 Min's then red. The Lamp led should flash red 1-2-3 or 4 time every 5 Min's. These are error codes that may point you in the right direction to you problem.
Hi, this is main board failure and you will need to replace this vital board. you power board is fine but, it is unable to send a proper current through the main mother board due to the damage at hand.
check the capacitors in the power supply that is the first thing to do, just check if anyone is swallen or pregnant jajajaja that's how some people call it
