Question about Nikon Coolpix 5700 Digital Camera
Repair of digital camera
Hi
When looking through the camera to take a picture it is virtually all black - it flickers a bit and the camera tries to focus  but all you see is darkness. In very bright light it goes slightly lighter but is still dark.
it will take pictures but they come out black
It did this a few weeks back - i then took all the pictures off the card and it worked - but then did the above again. I have again taken all the pictures off but it is still black this time
Any ideas?
looking throuhg thr lens and the viewfind all i see is black i take a picture and it comes out black eveythingthing esles is o.k battery is good
    Scholar:
  • 71 Answers
If you see all black in the viewfinder something bad has happened to the lens. It could be stuck, tilted, etc.
It will need to be taken apart and serviced by a trained technician.
Posted on Nov 15, 2007
Hello i have a problem with my canon powershot A1000Is digital camera. When i open the cam it only shows black screen and when i`m trying to take a picture is also black even if i check it on the computer...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Nov 20, 2010 | Canon Powershot A1000IS Digital Camera
Black screen when put it into camera mode
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
But if you do notice shutter movement, then this would then likely be a CCD imager failure. It would in that case require Canon service to repair (1-800-OK-CANON). Unfortunately if this is the case, believe that you may find that the estimated cost of repair may exceed the current value of the camera.
Dec 06, 2009 | Canon PowerShot A610 Digital Camera
Screen is black....will not display whats being taken a picture of nor is taking pictures.
Am assuming that you've already tried pressing the DISP button on the back of your camera. Is it not taking pictures, or are the pictures it is taking also black like the LCD? If black pictures, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Oct 10, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Black screen
Oct 06, 2009 | Canon PowerShot A510 Digital Camera
When camera is turned on the monitor is black, takes black pictures
hi..
A stuck shutter is common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter.....
thank u
Jul 10, 2009 | Olympus Stylus 850SW Digital Camera
Screen is black on playback & picture mode
Have you tried taking pictures when the screen is black? Do the pictures also come out black? If so, try putting it in any mode other than auto and turning off the flash (don't want to blind yourself for the next step). Next look down the front of the lens and take a picture. You should see a little flicker in the center of the lens as the shutter opens and closes. If you see this flicker, and you're still getting black pictures, then you likely have again encountered failure of the CCD. Canon will fix this again for you for free. See the following:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
But if no flicker or movement is seen down the center of the lens when you took the picture, then you likely have a stuck shutter. Canon will not fix this for free. But no matter, there are a couple simple fixes for this that don't require opening the camera: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jun 21, 2009 | Canon PowerShot A75 Digital Camera
Sony DSC-T700 PURPLE FLICKER
Let's try Initializing the Camera.
If you're able to access the Home Menu select the SETTINGS in the Home menu.
Then, select the MAIN SETTINGS under the SETTINGS.
Then, select the Initialize option under the MAIN SETTINGS to initialize the Camera.
If the issue still persists try Power Resetting the Camera.
To Power Reset the Camera, First, please turn OFF the Camera.
Then, remove the battery pack from the Camera.
Then, press and hold the POWER button on the Camera for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
If the issue still persists service of the Camera is required.
Jun 14, 2009 | Sony Cyber-shot DSC-T700 Digital Camera
The image veiwing window is mostly black, with horizontal
It sounds like your CCD image sensor is bad. Canon has issued a world wide technical notice regarding this, and will repair it at no cost if this is determined to be the problem, regardless of warranty.
Dec 09, 2008 | Canon PowerShot A85 Digital Camera
Taking picture
Your Canon A75 camera has problem in CCD Imager Sensor. Canon announced scheme to repair this fault free of cost. Click Canon CCD Advisory for details.
Bye.
Sep 12, 2008 | Canon PowerShot A75 Digital Camera
If you go to nikons home page you can search and find that they are willing to fix this free of charge.
Oct 27, 2007 | Nikon Coolpix 5700 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
114 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
