Question about GE Nautilus 24" Built-in Dishwasher
GE nautilus wont run
When you turn it on, just hums. I pulled bottom pannel and when I turn it on I can see the motor jump. Trys to turn but only moves a half inch or so and hums. Pulled the thre screws holding the motor on {oh and it wont pull out) and by turning the housing it rotates freely. The problem seems to be behind that... in the pump? I pulled the top screen off and can feel the little propeller/pump thing. Nothing seems to be jamed in there. I can turn it some... slow only so far. Is it maybe an o ring or seal sticking? How do I unstick it???? Thanks in advance!
  • 2 more comments
  • Dirty dish Nov 15, 2007
    Thanks. I ended up taking the the end apart, pretty easy actually when I looked at it a little closer. Rinsed it out and put it back together and it spun free. Have done two loads of dishes problem free.
    Thanks!!
  • cooldil Nov 26, 2007
    5 yr old GE Nautilus dishwasher won't run. I did the following:
    1) Loaded dishes
    2) Put dishwasher liquid
    3) Selected Normal Wash cycle
    4) Turned the knob to "Start"
    I could hear water filling up in the dishwasher. Once that is complete, the dishwasher doesn't run, though the dial keeps ticking away.
    I bought the house with this dishwasher only 2 weeks ago, and am trying to see if it has any problem. Any assistance is appreciated.
  • fwh202 Mar 17, 2008
    I had the same problem. As the solution states, use a couple screwdrivers to turn the fan. After a few tries (you'll posibly feel like you're breaking it... but hey, it's already broken, right) the fan rotates and the motor works.
    So far, so good. Only done one load of dishes, but this seems to work and has at least delayed a more costly repair or replacement.
    btw, our dishwasher is 5 yrs old.
    Thanks
  • Anonymous Jun 11, 2008
    I have the same problem, but I'm getting extremely tired of getting on the floor and "helping" the fan EVERY time I need to run the dishwasher. How difficult and expensive is it to replace this part. I have NO electrical knowledge, and my husband has even less. ü
  • 248 Answers
These motors were famous for the seal sticking to shaft. If this is an older unit turn the fan on motor by hand until it breaks free. Do this with power off.
Posted on Nov 15, 2007
No, don't use your hand after it has been running. It's hot! But turning the fan with a couple of screwdrivers until it breaks free and spins freely does work.
Posted on Nov 18, 2007
Push start button makes humming sound like it wants to start but wont run
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 05, 2011 | GE DRSR495EGWW Dryer
My GE Nautilus portable dishwasher will take water in, the motor will hum for a few minutes and then drain out into the sink. This process repeats but the water never cycles inside to actually wash the...
Try manually adding water to the dishwasher. If it works then the water valve is just clogged. Sometimes it gets full of gunk and the machine will take in water but not enough to run properly. It is in the upside down cup shaped thing on the bottom left front. The other possibility is the Cam/Timer. It is in the door right behind the dial. This is the part that triggers all the different actions.
If when you add water it doesn't work then the valve or the solenoid on the pump assembly is likely done.
Feb 24, 2011 | GE 25 in. Nautilus GSC3400J Free-standing...
CONSTANT HUMMING SOUND COMINFROM THE REFIRGIRATOR.
is it comming from the duct in the upper left corner or the bottom press a dowel or rod of some kind on the duct and your ear and then the bottom,of the noise is comming from up top the damper motor is probly bad.if down low the compressor is under there and may be running hot turn off the frige then unplug it remove the lower back pannel and clean the condencer coil it's on the left side it's silender shaped metal rods. i tape the big end of a funnel to my shop vac and put it on blow this is messy but gets it good and clean good luck
Dec 08, 2009 | GE GSS22IFP Side by Side Refrigerator
GE Nautilus Built-In Dishwasher
This would be the motor that spins the dish washing unit in the bottom. The noise you hear might mean that the motor will need to be replaced.
Sep 17, 2008 | GE Nautilus 24" Built-in Dishwasher
Nautilius not running
drain motor doesn't work, yo cn hear a little noise but maybe to hot, th motor doesn't turn.
Jun 29, 2008 | GE Nautilus 24" Built-in Dishwasher
GE NAUTILUS DISHWASHER
The pump motor may be stuck. If this is the case, as it often is with a GE dishwasher, you can break it loose (e.g. spin the impeller until it doesn't spring back any more). If it's not stuck, it may have something inside of the pump motor and it may need to be replaced.
Mar 25, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher No water when i turn it on
You need to prime the dishwasher by placing two large cups of water into the bottom.
Mar 19, 2008 | GE Nautilus 24" Built-in Dishwasher
Motor not running?
There is a pump motor underneath with an impeller that is most likely stuck. You will need to turn the impeller until it breaks loose if it is stuck. This is a common problem with GE dishwashers and I recommend that you run it at least once or twice a week to avoid this problem in the future, even if you have to run it empty.
Feb 27, 2008 | GE Nautilus 24" Built-in Dishwasher
if the dishwasher has not been used for a few weeks, the water in the sump that goes into the pump will evaporate causing the pump to freeze up. usually you can turn the fins inside the motor to free it up. make sure the dishwasher is not on when you do this.
Dec 05, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Nautilus bathroom fan blades don't turn
The motor is sized up. call someone to replace it and they should know how to remove the cover.
Nov 01, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
406 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
