FixYa.com
Tags:
Heaters
Generic problem for all Heaters
Boiler will not shut off (by 3 users)
posted by danbast on Nov 14, 2007
My boiler has been working fine for a few years, recently it does not shut off form some reason and I have to do it manually I was hoping it was the thermostat but I bought this one last year. It might be the wiring I dont know. Help!! Dan
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
2 Other Users Have The Same Problem
Comment by Guest, posted on Mar 13, 2008
We have a Honey Well system, our hot water heat system developed a leak - repaired that & replaced water in lines - bled lines for air locks - but now temp on furnace will rise to 210 - shut system completely down - can anyone help.
Comment by Guest, posted on Nov 20, 2007
Need a wiring diagram for the DUH1000 Utility heater
Best Solution
posted on Nov 15, 2007
Helpful (85)
Therinnaiguy
Rank:Guru Guru
Rating: 87%, 187 votes
Boilers are controlled by a few things, one being a thermostat, secondly a zone valve or circulator control and thirdly by an Aquastat that controls the boiler temperature and safety shutoff. If one of those controls is sticking, your boiler will turn or remain on until it reached a temperature where the safety control shuts it off. If your boiler is not shutting off at all, most likely it is the Aquastat control. The Aquastat will be located on the boiler and may have "Honeywell" printed or stamped on it. Take off the front cover and you will find model numbers on the backside of the cover. If you have some mechanical skills, you could probably replace it. Turn off your power first and wire it wire per wire.
If your boiler is shutting off on high limit, I would suspect a stuck zone valve or circulator control or a bad thermostat or shorted thermostat wire.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To: Coleman (5017B701) Utility Heater Coleman (5035A751) Heater Frontgate 18373 Heater Honeywell HZ519 Baseboard Heater Honeywell Electronic Ceramic Heater Honeywell HZ822 Mid-Size Heater Honeywell (7215B120H) Heater
Can you Help with these Heaters problems?
Heaters
Marivn 2060 Quartz Heater...
Well, I've already entered this... Answer This...
Goodman GMS90703BXA Heater
Heat Starter motor constantly...
i have a goodman 125-4 and the... Answer This...
Heaters
Honeywell HZ450 Switch needed
Where can I get a replacement... Answer This...
Coleman Propane Forced Air Heater...
central air unit
unit keeps freezing over-we... Answer This...
Honeywell Electronic Programmable Heat/Cool...
T8000C Honeywell - fuses???
had a power outage - checked... Answer This...
Repair Service
Find Heater Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
